gpio: delete unneeded test before of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Of_node_put supports NULL as its argument, so the initial test is not
necessary.
Suggested by Uwe Kleine-König.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e;
-if (e)
   of_node_put(e);
Signed-off-by: Julia Lawall
Signed-off-by: Linus Walleij
 drivers/gpio/gpiolib-of.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/gpio/gpiolib-of.c b/drivers/gpio/gpiolib-of.c
index 7cfdc22..604dbe6 100644
--- a/drivers/gpio/gpiolib-of.c
+++ b/drivers/gpio/gpiolib-of.c
@@ -307,7 +307,5 @@ void of_gpiochip_add(struct gpio_chip *chip)
 void of_gpiochip_remove(struct gpio_chip *chip)
 	gpiochip_remove_pin_ranges(chip);
-	if (chip->of_node)
-		of_node_put(chip->of_node);
+	of_node_put(chip->of_node);
BtrLinux
Privacy Overview
