GFS2: Use an IS_ERR test rather than a NULL test
Author: Julien Brunel <brunel@diku.dk>
In case of error, the function gfs2_inode_lookup returns an
ERR pointer, but never returns a NULL pointer. So a NULL test that
necessarily comes after an IS_ERR test should be deleted, and a NULL
test that may come after a call to this function should be
strengthened by an IS_ERR test.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@match_bad_null_test@
expression x, E;
statement S1,S2;
x = gfs2_inode_lookup(...)
... when != x = E
* if (x != NULL)
S1 else S2
Signed-off-by: Julien Brunel
Signed-off-by: Julia Lawall
Signed-off-by: Steven Whitehouse
fs/gfs2/inode.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/fs/gfs2/inode.c b/fs/gfs2/inode.c
index 8752552..c8a959c 100644
--- a/fs/gfs2/inode.c
+++ b/fs/gfs2/inode.c
@@ -1033,13 +1033,11 @@ struct inode *gfs2_createi(struct gfs2_holder *ghs, const struct qstr *name,
if (bh)
brelse(bh);
- if (!inode)
- return ERR_PTR(-ENOMEM);
return inode;
fail_gunlock2:
gfs2_glock_dq_uninit(ghs + 1);
- if (inode)
+ if (inode && !IS_ERR(inode))
iput(inode);
fail_gunlock:
gfs2_glock_dq(ghs); |
if (bh)
brelse(bh);
- if (!inode)
return inode;
fail_gunlock2:
- if (inode)
iput(inode);
fail_gunlock:
gfs2_glock_dq(ghs);
