[GFS2] test for IS_ERR rather than 0
The function gfs2_inode_lookup always returns either a valid pointer or a
value made with ERR_PTR, so its result should be tested with IS_ERR, not
with a test for 0.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
@a@
expression E, E1;
statement S,S1;
position p;
E = gfs2_inode_lookup(...)
... when != E = E1
if@p (E) S else S1
@n@
position a.p;
expression E,E1;
statement S,S1;
E = NULL
... when != E = E1
if@p (E) S else S1
@depends on !n@
expression E;
statement S,S1;
position a.p;
* if@p (E)
  S else S1
Signed-off-by: Julia Lawall
Signed-off-by: Steven Whitehouse
 fs/gfs2/ops_export.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/fs/gfs2/ops_export.c b/fs/gfs2/ops_export.c
index 334c7f8..990d9f4 100644
--- a/fs/gfs2/ops_export.c
+++ b/fs/gfs2/ops_export.c
@@ -204,8 +204,6 @@ static struct dentry *gfs2_get_dentry(struct super_block *sb,
 	inode = gfs2_inode_lookup(sb, DT_UNKNOWN,
 					inum->no_addr,
 					0, 0);
-	if (!inode)
-		goto fail;
 	if (IS_ERR(inode)) {
 		error = PTR_ERR(inode);
 		goto fail;
BtrLinux
Privacy Overview
