fujitsu-laptop: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
These functions mix the use of result and error.  In acpi_fujitsu_add,
result does not seem useful; it would seem reasonable to propagate the
return value of acpi_bus_update_power in an error case.  On the other hand,
in the case of acpi_fujitsu_hotkey_add, there is an initialization of
result that can lead to what looks like a failure case, but that does not
abort the function.  The variable result is kept for this case.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Matthew Garrett
 drivers/platform/x86/fujitsu-laptop.c | 15 +++++++--------
 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/platform/x86/fujitsu-laptop.c b/drivers/platform/x86/fujitsu-laptop.c
index 9d30d69..be02bcc 100644
--- a/drivers/platform/x86/fujitsu-laptop.c
+++ b/drivers/platform/x86/fujitsu-laptop.c
@@ -633,7 +633,6 @@ static struct dmi_system_id fujitsu_dmi_table[] = {
 static int acpi_fujitsu_add(struct acpi_device *device)
-	int result = 0;
 	int state = 0;
 	struct input_dev *input;
 	int error;
@@ -669,8 +668,8 @@ static int acpi_fujitsu_add(struct acpi_device *device)
 	if (error)
 		goto err_free_input_dev;
-	result = acpi_bus_update_power(fujitsu->acpi_handle, &state);
-	if (result) {
+	error = acpi_bus_update_power(fujitsu->acpi_handle, &state);
+	if (error) {
 		pr_err("Error reading power state\n");
 		goto err_unregister_input_dev;
@@ -700,7 +699,7 @@ static int acpi_fujitsu_add(struct acpi_device *device)
 		fujitsu->max_brightness = FUJITSU_LCD_N_LEVELS;
 	get_lcd_level();
-	return result;
+	return 0;
 err_unregister_input_dev:
 	input_unregister_device(input);
@@ -708,7 +707,7 @@ err_unregister_input_dev:
 err_free_input_dev:
 	input_free_device(input);
 err_stop:
-	return result;
+	return error;
 static int acpi_fujitsu_remove(struct acpi_device *device)
@@ -831,8 +830,8 @@ static int acpi_fujitsu_hotkey_add(struct acpi_device *device)
 	if (error)
-	result = acpi_bus_update_power(fujitsu_hotkey->acpi_handle, &state);
-	if (result) {
+	error = acpi_bus_update_power(fujitsu_hotkey->acpi_handle, &state);
+	if (error) {
@@ -907,7 +906,7 @@ err_free_input_dev:
 err_free_fifo:
 	kfifo_free(&fujitsu_hotkey->fifo);
 err_stop:
-	return result;
+	return error;
 static int acpi_fujitsu_hotkey_remove(struct acpi_device *device)
BtrLinux
Privacy Overview
