fujitsu-laptop: Correct redundant test
device and acpi_driver_data(device) were tested just a few lines above.
A simplified version of the semantic match that finds this problem is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
if (x == NULL || ...) { ... when forall
   return ...; }
.. when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
*x == NULL
*x != NULL
Signed-off-by: Julia Lawall
Acked-by: Jonathan Woithe
Signed-off-by: Len Brown
 drivers/platform/x86/fujitsu-laptop.c | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/drivers/platform/x86/fujitsu-laptop.c b/drivers/platform/x86/fujitsu-laptop.c
index 4c8897a..0d42f44 100644
--- a/drivers/platform/x86/fujitsu-laptop.c
+++ b/drivers/platform/x86/fujitsu-laptop.c
@@ -745,9 +745,6 @@ static int acpi_fujitsu_remove(struct acpi_device *device, int type)
 	fujitsu = acpi_driver_data(device);
-	if (!device || !acpi_driver_data(device))
-		return -EINVAL;
 	fujitsu->acpi_handle = NULL;
 	return 0;
BtrLinux
Privacy Overview
