fs/udf: Use DIV_ROUND_UP
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) /
(d)) but is perhaps more readable.
An extract of the semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP((n),d)
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP(n,(d))
+ DIV_ROUND_UP(n,d)
Signed-off-by: Julia Lawall
Signed-off-by: Jan Kara
 fs/udf/super.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/fs/udf/super.c b/fs/udf/super.c
index 02815e9..5f0d400 100644
--- a/fs/udf/super.c
+++ b/fs/udf/super.c
@@ -986,10 +986,9 @@ static void udf_load_fileset(struct super_block *sb, struct buffer_head *bh,
 int udf_compute_nr_groups(struct super_block *sb, u32 partition)
 	struct udf_part_map *map = &UDF_SB(sb)->s_partmaps[partition];
-	return (map->s_partition_len +
-		(sizeof(struct spaceBitmapDesc) << 3) +
-		(sb->s_blocksize * 8) - 1) /
-		(sb->s_blocksize * 8);
+	return DIV_ROUND_UP(map->s_partition_len +
+			    (sizeof(struct spaceBitmapDesc) << 3),
+			    sb->s_blocksize * 8);
 static struct udf_bitmap *udf_sb_alloc_bitmap(struct super_block *sb, u32 index)
BtrLinux
Privacy Overview
