fs/reiserfs/super.c: correct use of ! and &
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337 ("wmi: (!x & y)
strikes again"), a bug was fixed that involved converting !x & y to !(x
& y).  The code below shows the same pattern, and thus should perhaps be
fixed in the same way.
This is not tested and clearly changes the semantics, so it is only
something to consider.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E1,E2; @@
  !E1 & !E2
- !E1 & E2
+ !(E1 & E2)
Signed-off-by: Julia Lawall
Cc: Chris Mason
Cc: Jeff Mahoney
Cc: Jan Kara
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/reiserfs/super.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/reiserfs/super.c b/fs/reiserfs/super.c
index 6841452..393cc22c 100644
--- a/fs/reiserfs/super.c
+++ b/fs/reiserfs/super.c
@@ -2031,7 +2031,7 @@ static int reiserfs_quota_on(struct super_block *sb, int type, int format_id,
 		return -EXDEV;
 	/* We must not pack tails for quota files on reiserfs for quota IO to work */
-	if (!REISERFS_I(nd.path.dentry->d_inode)->i_flags & i_nopack_mask) {
+	if (!(REISERFS_I(nd.path.dentry->d_inode)->i_flags & i_nopack_mask)) {
 		reiserfs_warning(sb,
 				 "reiserfs: Quota file must have tail packing disabled.");
 		path_put(&nd.path);
