fs/ocfs2/dlm: Drop memory allocation cast
Drop cast on the result of kmalloc and similar functions.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
- (T *)
  (\(kmalloc\|kzalloc\|kcalloc\|kmem_cache_alloc\|kmem_cache_zalloc\|
   kmem_cache_alloc_node\|kmalloc_node\|kzalloc_node\)(...))
Signed-off-by: Julia Lawall
Signed-off-by: Joel Becker
 fs/ocfs2/dlm/dlmlock.c   |  2 +-
 fs/ocfs2/dlm/dlmmaster.c | 18 ++++++------------
 2 files changed, 7 insertions(+), 13 deletions(-)
diff --git a/fs/ocfs2/dlm/dlmlock.c b/fs/ocfs2/dlm/dlmlock.c
index f1fba2a..69cf369 100644
--- a/fs/ocfs2/dlm/dlmlock.c
+++ b/fs/ocfs2/dlm/dlmlock.c
@@ -431,7 +431,7 @@ struct dlm_lock * dlm_new_lock(int type, u8 node, u64 cookie,
 	struct dlm_lock *lock;
 	int kernel_allocated = 0;
-	lock = (struct dlm_lock *) kmem_cache_zalloc(dlm_lock_cache, GFP_NOFS);
+	lock = kmem_cache_zalloc(dlm_lock_cache, GFP_NOFS);
 	if (!lock)
 		return NULL;
diff --git a/fs/ocfs2/dlm/dlmmaster.c b/fs/ocfs2/dlm/dlmmaster.c
index 3114de2..b01e348 100644
--- a/fs/ocfs2/dlm/dlmmaster.c
+++ b/fs/ocfs2/dlm/dlmmaster.c
@@ -617,13 +617,11 @@ struct dlm_lock_resource *dlm_new_lockres(struct dlm_ctxt *dlm,
 	struct dlm_lock_resource *res = NULL;
-	res = (struct dlm_lock_resource *)
-				kmem_cache_zalloc(dlm_lockres_cache, GFP_NOFS);
+	res = kmem_cache_zalloc(dlm_lockres_cache, GFP_NOFS);
 	if (!res)
 		goto error;
-	res->lockname.name = (char *)
-				kmem_cache_zalloc(dlm_lockname_cache, GFP_NOFS);
+	res->lockname.name = kmem_cache_zalloc(dlm_lockname_cache, GFP_NOFS);
 	if (!res->lockname.name)
 		goto error;
@@ -757,8 +755,7 @@ lookup:
 		spin_unlock(&dlm->spinlock);
 		mlog(0, "allocating a new resource\n");
 		/* nothing found and we need to allocate one. */
-		alloc_mle = (struct dlm_master_list_entry *)
-			kmem_cache_alloc(dlm_mle_cache, GFP_NOFS);
+		alloc_mle = kmem_cache_alloc(dlm_mle_cache, GFP_NOFS);
 		if (!alloc_mle)
 			goto leave;
 		res = dlm_new_lockres(dlm, lockid, namelen);
@@ -1542,8 +1539,7 @@ way_up_top:
 			spin_unlock(&dlm->master_lock);
-			mle = (struct dlm_master_list_entry *)
+			mle = kmem_cache_alloc(dlm_mle_cache, GFP_NOFS);
 			if (!mle) {
 				response = DLM_MASTER_RESP_ERROR;
 				mlog_errno(-ENOMEM);
@@ -2458,8 +2454,7 @@ static int dlm_migrate_lockres(struct dlm_ctxt *dlm,
 		goto leave;
-	mle = (struct dlm_master_list_entry *) kmem_cache_alloc(dlm_mle_cache,
-								GFP_NOFS);
 	if (!mle) {
 		mlog_errno(ret);
 		goto leave;
@@ -3041,8 +3036,7 @@ int dlm_migrate_request_handler(struct o2net_msg *msg, u32 len, void *data,
 	hash = dlm_lockid_hash(name, namelen);
 	/* preallocate.. if this fails, abort */
-							 GFP_NOFS);
 	if (!mle) {
 		ret = -ENOMEM;
BtrLinux
Privacy Overview
