fs/ocfs2/dlm: Add missing spin_unlock
Add a spin_unlock missing on the error path.  Unlock as in the other code
that leads to the leave label.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* spin_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* spin_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: Joel Becker
 fs/ocfs2/dlm/dlmdomain.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/fs/ocfs2/dlm/dlmdomain.c b/fs/ocfs2/dlm/dlmdomain.c
index 6b5a492..2ccad86 100644
--- a/fs/ocfs2/dlm/dlmdomain.c
+++ b/fs/ocfs2/dlm/dlmdomain.c
@@ -1709,6 +1709,7 @@ retry:
 		if (dlm_protocol_compare(&dlm->fs_locking_proto, fs_proto)) {
+			spin_unlock(&dlm_domain_lock);
 			mlog(ML_ERROR,
 			     "Requested locking protocol version is not "
 			     "compatible with already registered domain "
