fs/nfsd/export.c: Adjust error handling code involving auth_domain_put
Once clp is assigned, it never becomes NULL, so we can make a label for it
in the error handling code.  Because the call to path_lookup follows the
call to auth_domain_find, its error handling code should jump to this new
label.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r@
expression x,E;
statement S;
position p1,p2,p3;
if ((x = auth_domain_find@p1(...)) == NULL || ...) S
... when != x
if (x == NULL || ...) S
if@p3 (...) { ... when != auth_domain_put(x)
                  when != if (x) { ... auth_domain_put(x); ...}
    return@p2 ...;
return x;
return 0;
x = E
E = x
auth_domain_put(x)
@exists@
position r.p1,r.p2,r.p3;
expression x;
int ret != 0;
statement S;
* x = auth_domain_find@p1(...)
* if@p3 (...)
  S
* return@p2 \(NULL\|ret\);
Signed-off-by: Julia Lawall
Signed-off-by: J. Bruce Fields
 fs/nfsd/export.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/fs/nfsd/export.c b/fs/nfsd/export.c
index 33bfcf0..9dc036f 100644
--- a/fs/nfsd/export.c
+++ b/fs/nfsd/export.c
@@ -1023,7 +1023,7 @@ exp_export(struct nfsctl_export *nxp)
 	/* Look up the dentry */
 	err = path_lookup(nxp->ex_path, 0, &nd);
 	if (err)
-		goto out_unlock;
+		goto out_put_clp;
 	err = -EINVAL;
 	exp = exp_get_by_name(clp, nd.path.mnt, nd.path.dentry, NULL);
@@ -1090,9 +1090,9 @@ finish:
 		exp_put(exp);
 	if (fsid_key && !IS_ERR(fsid_key))
 		cache_put(&fsid_key->h, &svc_expkey_cache);
-	if (clp)
-		auth_domain_put(clp);
 	path_put(&nd.path);
+out_put_clp:
+	auth_domain_put(clp);
 out_unlock:
 	exp_writeunlock();
 out:
BtrLinux
Privacy Overview
