fsl/fman: Delete one function call “put_device” in dtsec_config()
Author: Markus Elfring <elfring@users.sourceforge.net>
The Coccinelle semantic patch script "deref_null.cocci" pointed a problem
out in the implementation of the function "dtsec_config".
A null pointer was assigned to the data structure member "tbiphy" of the
variable "dtsec" if a matching device was not found.
A call of the function "put_device" was unnecessary then because
a previous call of the function "get_device" was not triggered.
Thus remove the function call "put_device" after the printing of the
desired error message.
Signed-off-by: Markus Elfring
Signed-off-by: David S. Miller
drivers/net/ethernet/freescale/fman/fman_dtsec.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/drivers/net/ethernet/freescale/fman/fman_dtsec.c b/drivers/net/ethernet/freescale/fman/fman_dtsec.c
index 6b1261c..7c92eb8 100644
--- a/drivers/net/ethernet/freescale/fman/fman_dtsec.c
+++ b/drivers/net/ethernet/freescale/fman/fman_dtsec.c
@@ -1434,7 +1434,6 @@ struct fman_mac *dtsec_config(struct fman_mac_params *params)
dtsec->tbiphy = of_phy_find_device(params->internal_phy_node);
if (!dtsec->tbiphy) {
pr_err("of_phy_find_device (TBI PHY) failed\n");
- put_device(&dtsec->tbiphy->mdio.dev);
goto err_dtsec_drv_param;
