fs/ext3/balloc.c: delete useless initialization
Delete nontrivial initialization that is immediately overwritten by the
result of an allocation function.
The semantic match that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
identifier i;
expression e;
T i = \(0\|NULL\|ERR_PTR(...)\);
-T i = e;
+T i;
... when != i
i = \(kzalloc\|kcalloc\|kmalloc\)(...);
Signed-off-by: Julia Lawall
Signed-off-by: Jan Kara
fs/ext3/balloc.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/ext3/balloc.c b/fs/ext3/balloc.c
index 6386d76..caedc00 100644
--- a/fs/ext3/balloc.c
+++ b/fs/ext3/balloc.c
@@ -427,7 +427,7 @@ static inline int rsv_is_empty(struct ext3_reserve_window *rsv)
void ext3_init_block_alloc_info(struct inode *inode)
struct ext3_inode_info *ei = EXT3_I(inode);
- struct ext3_block_alloc_info *block_i = ei->i_block_alloc_info;
+ struct ext3_block_alloc_info *block_i;
struct super_block *sb = inode->i_sb;
block_i = kmalloc(sizeof(*block_i), GFP_NOFS); |
