fs/ext2: use BUG_ON
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ disable unlikely @ expression E,f; @@
  if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/ext2/balloc.c | 3 +--
 fs/ext2/dir.c    | 4 ++--
 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/fs/ext2/balloc.c b/fs/ext2/balloc.c
index e7b2baf..c834f512 100644
--- a/fs/ext2/balloc.c
+++ b/fs/ext2/balloc.c
@@ -245,8 +245,7 @@ restart:
 		prev = rsv;
 	printk("Window map complete.\n");
-	if (bad)
-		BUG();
+	BUG_ON(bad);
 #define rsv_window_dump(root, verbose) \
 	__rsv_window_dump((root), (verbose), __FUNCTION__)
diff --git a/fs/ext2/dir.c b/fs/ext2/dir.c
index a0995eb..dd9dbb2 100644
--- a/fs/ext2/dir.c
+++ b/fs/ext2/dir.c
@@ -41,8 +41,8 @@ static inline __le16 ext2_rec_len_to_disk(unsigned len)
 	if (len == (1 << 16))
 		return cpu_to_le16(EXT2_MAX_REC_LEN);
-	else if (len > (1 << 16))
-		BUG();
+	else
+		BUG_ON(len > (1 << 16));
 	return cpu_to_le16(len);
BtrLinux
Privacy Overview
