fs/ecryptfs/file.c: introduce missing free
The comments in the code indicate that file_info should be released if the
function fails.  This releasing is done at the label out_free, not out.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = kmem_cache_zalloc(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return <+...x...+>;
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmem_cache_zalloc %s" % (p1[0].file,p1[0].line)
Signed-off-by: Julia Lawall
Cc: stable@kernel.org
Signed-off-by: Tyler Hicks
 fs/ecryptfs/file.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/fs/ecryptfs/file.c b/fs/ecryptfs/file.c
index 6e4f84c..622c9514 100644
--- a/fs/ecryptfs/file.c
+++ b/fs/ecryptfs/file.c
@@ -199,7 +199,7 @@ static int ecryptfs_open(struct inode *inode, struct file *file)
 			       "the persistent file for the dentry with name "
 			       "[%s]; rc = [%d]\n", __func__,
 			       ecryptfs_dentry->d_name.name, rc);
-			goto out;
+			goto out_free;
 	if ((ecryptfs_inode_to_private(inode)->lower_file->f_flags & O_RDONLY)
@@ -207,7 +207,7 @@ static int ecryptfs_open(struct inode *inode, struct file *file)
 		rc = -EPERM;
 		printk(KERN_WARNING "%s: Lower persistent file is RO; eCryptfs "
 		       "file must hence be opened RO\n", __func__);
-		goto out;
+		goto out_free;
 	ecryptfs_set_file_lower(
 		file, ecryptfs_inode_to_private(inode)->lower_file);
BtrLinux
Privacy Overview
