fs/btrfs/inode.c: Add missing IS_ERR test
After the conditional that precedes the following code, inode may be an
ERR_PTR value.  This can eg result from a memory allocation failure via the
call to btrfs_iget, and thus does not imply that root is different than
sub_root.  Thus, an IS_ERR check is added to ensure that there is no
dereference of inode in this case.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
identifier f;
f(...) { ... return ERR_PTR(...); }
identifier r.f, fld;
expression x;
statement S1,S2;
 x = f(...)
 ... when != IS_ERR(x)
 if (IS_ERR(x) ||...) S1 else S2
*x->fld
Signed-off-by: Julia Lawall
Signed-off-by: Chris Mason
 fs/btrfs/inode.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/btrfs/inode.c b/fs/btrfs/inode.c
index 2c9a2f7..2b7d251 100644
--- a/fs/btrfs/inode.c
+++ b/fs/btrfs/inode.c
@@ -4137,7 +4137,7 @@ struct inode *btrfs_lookup_dentry(struct inode *dir, struct dentry *dentry)
 	srcu_read_unlock(&root->fs_info->subvol_srcu, index);
-	if (root != sub_root) {
+	if (!IS_ERR(inode) && root != sub_root) {
 		down_read(&root->fs_info->cleanup_work_sem);
 		if (!(inode->i_sb->s_flags & MS_RDONLY))
 			btrfs_orphan_cleanup(sub_root);
BtrLinux
Privacy Overview
