fs/btrfs: use WARN
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use WARN rather than printk followed by WARN_ON(1), for conciseness.
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression list es;
-printk(
+WARN(1,
  es);
-WARN_ON(1);
Signed-off-by: Julia Lawall
Reviewed-by: David Sterba
Signed-off-by: Chris Mason
 fs/btrfs/ctree.c       | 19 +++++++------------
 fs/btrfs/disk-io.c     |  6 ++----
 fs/btrfs/extent-tree.c |  7 +++----
 fs/btrfs/extent_io.c   |  9 +++------
 fs/btrfs/inode.c       |  3 +--
 fs/btrfs/transaction.c | 12 ++++--------
 fs/btrfs/volumes.c     |  3 +--
 7 files changed, 21 insertions(+), 38 deletions(-)
diff --git a/fs/btrfs/ctree.c b/fs/btrfs/ctree.c
index 100c274..0e4adb0 100644
--- a/fs/btrfs/ctree.c
+++ b/fs/btrfs/ctree.c
@@ -1359,19 +1359,16 @@ noinline int btrfs_cow_block(struct btrfs_trans_handle *trans,
 	u64 search_start;
 	int ret;
-	if (trans->transaction != root->fs_info->running_transaction) {
-		printk(KERN_CRIT "trans %llu running %llu\n",
+	if (trans->transaction != root->fs_info->running_transaction)
+		WARN(1, KERN_CRIT "trans %llu running %llu\n",
 		       (unsigned long long)trans->transid,
 		       root->fs_info->running_transaction->transid);
-		WARN_ON(1);
-	if (trans->transid != root->fs_info->generation) {
+	if (trans->transid != root->fs_info->generation)
 		       (unsigned long long)root->fs_info->generation);
-		WARN_ON(1);
 	if (!should_cow_block(trans, root, buf)) {
 		*cow_ret = buf;
@@ -3640,11 +3637,9 @@ static noinline int __push_leaf_left(struct btrfs_trans_handle *trans,
 	btrfs_set_header_nritems(left, old_left_nritems + push_items);
 	/* fixup right node */
-	if (push_items > right_nritems) {
-		printk(KERN_CRIT "push items %d nr %u\n", push_items,
+	if (push_items > right_nritems)
+		WARN(1, KERN_CRIT "push items %d nr %u\n", push_items,
 		       right_nritems);
-		WARN_ON(1);
 	if (push_items < right_nritems) {
 		push_space = btrfs_item_offset_nr(right, push_items - 1) -
diff --git a/fs/btrfs/disk-io.c b/fs/btrfs/disk-io.c
index 0643159..07a2162 100644
--- a/fs/btrfs/disk-io.c
+++ b/fs/btrfs/disk-io.c
@@ -3397,14 +3397,12 @@ void btrfs_mark_buffer_dirty(struct extent_buffer *buf)
 	int was_dirty;
 	btrfs_assert_tree_locked(buf);
-	if (transid != root->fs_info->generation) {
-		printk(KERN_CRIT "btrfs transid mismatch buffer %llu, "
+	if (transid != root->fs_info->generation)
+		WARN(1, KERN_CRIT "btrfs transid mismatch buffer %llu, "
 		       "found %llu running %llu\n",
 			(unsigned long long)buf->start,
 			(unsigned long long)transid,
-		WARN_ON(1);
 	was_dirty = set_extent_buffer_dirty(buf);
 	if (!was_dirty) {
 		spin_lock(&root->fs_info->delalloc_lock);
diff --git a/fs/btrfs/extent-tree.c b/fs/btrfs/extent-tree.c
index b495cb4..0bcb954 100644
--- a/fs/btrfs/extent-tree.c
+++ b/fs/btrfs/extent-tree.c
@@ -6292,10 +6292,9 @@ use_block_rsv(struct btrfs_trans_handle *trans,
 		static DEFINE_RATELIMIT_STATE(_rs,
 				DEFAULT_RATELIMIT_INTERVAL,
 				/*DEFAULT_RATELIMIT_BURST*/ 2);
-		if (__ratelimit(&_rs)) {
-			printk(KERN_DEBUG "btrfs: block rsv returned %d\n", ret);
-			WARN_ON(1);
+		if (__ratelimit(&_rs))
+			WARN(1, KERN_DEBUG "btrfs: block rsv returned %d\n",
+			     ret);
 		ret = reserve_metadata_bytes(root, block_rsv, blocksize,
 					     BTRFS_RESERVE_NO_FLUSH);
 		if (!ret) {
diff --git a/fs/btrfs/extent_io.c b/fs/btrfs/extent_io.c
index 472873a..3c062c8 100644
--- a/fs/btrfs/extent_io.c
+++ b/fs/btrfs/extent_io.c
@@ -341,12 +341,10 @@ static int insert_state(struct extent_io_tree *tree,
 	struct rb_node *node;
-	if (end < start) {
-		printk(KERN_ERR "btrfs end < start %llu %llu\n",
+	if (end < start)
+		WARN(1, KERN_ERR "btrfs end < start %llu %llu\n",
 		       (unsigned long long)end,
 		       (unsigned long long)start);
-		WARN_ON(1);
 	state->start = start;
 	state->end = end;
@@ -4721,10 +4719,9 @@ int map_private_extent_buffer(struct extent_buffer *eb, unsigned long start,
 	if (start + min_len > eb->len) {
-		printk(KERN_ERR "btrfs bad mapping eb start %llu len %lu, "
+		WARN(1, KERN_ERR "btrfs bad mapping eb start %llu len %lu, "
 		       "wanted %lu %lu\n", (unsigned long long)eb->start,
 		       eb->len, start, min_len);
-		WARN_ON(1);
 		return -EINVAL;
diff --git a/fs/btrfs/inode.c b/fs/btrfs/inode.c
index 96d2090..6dca345 100644
--- a/fs/btrfs/inode.c
+++ b/fs/btrfs/inode.c
@@ -5458,8 +5458,7 @@ again:
 				    extent_map_end(em) - 1, NULL, GFP_NOFS);
 		goto insert;
 	} else {
-		printk(KERN_ERR "btrfs unknown found_type %d\n", found_type);
-		WARN_ON(1);
+		WARN(1, KERN_ERR "btrfs unknown found_type %d\n", found_type);
 not_found:
 	em->start = start;
diff --git a/fs/btrfs/transaction.c b/fs/btrfs/transaction.c
index bc1f523..f21f39f 100644
--- a/fs/btrfs/transaction.c
+++ b/fs/btrfs/transaction.c
@@ -145,16 +145,12 @@ loop:
 	 * the log must never go across transaction boundaries.
 	smp_mb();
-	if (!list_empty(&fs_info->tree_mod_seq_list)) {
-		printk(KERN_ERR "btrfs: tree_mod_seq_list not empty when "
+	if (!list_empty(&fs_info->tree_mod_seq_list))
+		WARN(1, KERN_ERR "btrfs: tree_mod_seq_list not empty when "
 			"creating a fresh transaction\n");
-		WARN_ON(1);
-	if (!RB_EMPTY_ROOT(&fs_info->tree_mod_log)) {
-		printk(KERN_ERR "btrfs: tree_mod_log rb tree not empty when "
+	if (!RB_EMPTY_ROOT(&fs_info->tree_mod_log))
+		WARN(1, KERN_ERR "btrfs: tree_mod_log rb tree not empty when "
-		WARN_ON(1);
 	atomic_set(&fs_info->tree_mod_seq, 0);
 	spin_lock_init(&cur_trans->commit_lock);
diff --git a/fs/btrfs/volumes.c b/fs/btrfs/volumes.c
index eeed97d..3f4bfee 100644
--- a/fs/btrfs/volumes.c
+++ b/fs/btrfs/volumes.c
@@ -3323,9 +3323,8 @@ static int __btrfs_alloc_chunk(struct btrfs_trans_handle *trans,
 		cur = cur->next;
 		if (!device->writeable) {
-			printk(KERN_ERR
+			WARN(1, KERN_ERR
 			       "btrfs: read-only device in alloc_list\n");
-			WARN_ON(1);
 			continue;
BtrLinux
Privacy Overview
