fs/btrfs: drop if around WARN_ON
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Just use WARN_ON rather than an if containing only WARN_ON(1).
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression e;
- if (e) WARN_ON(1);
+ WARN_ON(e);
Signed-off-by: Julia Lawall
Reviewed-by: David Sterba
Signed-off-by: Chris Mason
 fs/btrfs/backref.c | 3 +--
 fs/btrfs/ctree.c   | 9 +++------
 fs/btrfs/inode.c   | 3 +--
 3 files changed, 5 insertions(+), 10 deletions(-)
diff --git a/fs/btrfs/backref.c b/fs/btrfs/backref.c
index 208d8aa..a321952 100644
--- a/fs/btrfs/backref.c
+++ b/fs/btrfs/backref.c
@@ -890,8 +890,7 @@ again:
 	while (!list_empty(&prefs)) {
 		ref = list_first_entry(&prefs, struct __prelim_ref, list);
 		list_del(&ref->list);
-		if (ref->count < 0)
-			WARN_ON(1);
+		WARN_ON(ref->count < 0);
 		if (ref->count && ref->root_id && ref->parent == 0) {
 			/* no parent == root of tree */
 			ret = ulist_add(roots, ref->root_id, 0, GFP_NOFS);
diff --git a/fs/btrfs/ctree.c b/fs/btrfs/ctree.c
index 0e4adb0..5c2cf99 100644
--- a/fs/btrfs/ctree.c
+++ b/fs/btrfs/ctree.c
@@ -1464,10 +1464,8 @@ int btrfs_realloc_node(struct btrfs_trans_handle *trans,
 	if (cache_only && parent_level != 1)
 		return 0;
-	if (trans->transaction != root->fs_info->running_transaction)
-		WARN_ON(1);
-	if (trans->transid != root->fs_info->generation)
-		WARN_ON(1);
+	WARN_ON(trans->transaction != root->fs_info->running_transaction);
+	WARN_ON(trans->transid != root->fs_info->generation);
 	parent_nritems = btrfs_header_nritems(parent);
 	blocksize = btrfs_level_size(root, parent_level - 1);
@@ -3398,8 +3396,7 @@ static noinline int __push_leaf_right(struct btrfs_trans_handle *trans,
 	if (push_items == 0)
 		goto out_unlock;
-	if (!empty && push_items == left_nritems)
-		WARN_ON(1);
+	WARN_ON(!empty && push_items == left_nritems);
 	/* push left to right */
 	right_nritems = btrfs_header_nritems(right);
diff --git a/fs/btrfs/inode.c b/fs/btrfs/inode.c
index 6dca345..e8733fa 100644
--- a/fs/btrfs/inode.c
+++ b/fs/btrfs/inode.c
@@ -1675,8 +1675,7 @@ static noinline int add_pending_csums(struct btrfs_trans_handle *trans,
 int btrfs_set_extent_delalloc(struct inode *inode, u64 start, u64 end,
 			      struct extent_state **cached_state)
-	if ((end & (PAGE_CACHE_SIZE - 1)) == 0)
-		WARN_ON(1);
+	WARN_ON((end & (PAGE_CACHE_SIZE - 1)) == 0);
 	return set_extent_delalloc(&BTRFS_I(inode)->io_tree, start, end,
 				   cached_state, GFP_NOFS);
BtrLinux
Privacy Overview
