fs/affs/file.c: use BUG_ON
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ disable unlikely @ expression E,f; @@
  if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
Signed-off-by: Julia Lawall
Cc: Roman Zippel
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/affs/file.c | 21 +++++++--------------
 1 file changed, 7 insertions(+), 14 deletions(-)
diff --git a/fs/affs/file.c b/fs/affs/file.c
index 6e0c939..e87ede6 100644
--- a/fs/affs/file.c
+++ b/fs/affs/file.c
@@ -325,8 +325,7 @@ affs_get_block(struct inode *inode, sector_t block, struct buffer_head *bh_resul
 	pr_debug("AFFS: get_block(%u, %lu)\n", (u32)inode->i_ino, (unsigned long)block);
-	if (block > (sector_t)0x7fffffffUL)
-		BUG();
+	BUG_ON(block > (sector_t)0x7fffffffUL);
 	if (block >= AFFS_I(inode)->i_blkcnt) {
 		if (block > AFFS_I(inode)->i_blkcnt || !create)
@@ -493,8 +492,7 @@ affs_do_readpage_ofs(struct file *file, struct page *page, unsigned from, unsign
 	u32 tmp;
 	pr_debug("AFFS: read_page(%u, %ld, %d, %d)\n", (u32)inode->i_ino, page->index, from, to);
-	if (from > to || to > PAGE_CACHE_SIZE)
-		BUG();
+	BUG_ON(from > to || to > PAGE_CACHE_SIZE);
 	kmap(page);
 	data = page_address(page);
 	bsize = AFFS_SB(sb)->s_data_blksize;
@@ -507,8 +505,7 @@ affs_do_readpage_ofs(struct file *file, struct page *page, unsigned from, unsign
 		if (IS_ERR(bh))
 			return PTR_ERR(bh);
 		tmp = min(bsize - boff, to - from);
-		if (from + tmp > to || tmp > bsize)
-			BUG();
+		BUG_ON(from + tmp > to || tmp > bsize);
 		memcpy(data + from, AFFS_DATA(bh) + boff, tmp);
 		affs_brelse(bh);
 		bidx++;
@@ -540,8 +537,7 @@ affs_extent_file_ofs(struct inode *inode, u32 newsize)
 		if (IS_ERR(bh))
 			return PTR_ERR(bh);
 		tmp = min(bsize - boff, newsize - size);
-		if (boff + tmp > bsize || tmp > bsize)
-			BUG();
+		BUG_ON(boff + tmp > bsize || tmp > bsize);
 		memset(AFFS_DATA(bh) + boff, 0, tmp);
 		AFFS_DATA_HEAD(bh)->size = cpu_to_be32(be32_to_cpu(AFFS_DATA_HEAD(bh)->size) + tmp);
 		affs_fix_checksum(sb, bh);
@@ -560,8 +556,7 @@ affs_extent_file_ofs(struct inode *inode, u32 newsize)
 		if (IS_ERR(bh))
 			goto out;
 		tmp = min(bsize, newsize - size);
-		if (tmp > bsize)
-			BUG();
+		BUG_ON(tmp > bsize);
 		AFFS_DATA_HEAD(bh)->ptype = cpu_to_be32(T_DATA);
 		AFFS_DATA_HEAD(bh)->key = cpu_to_be32(inode->i_ino);
 		AFFS_DATA_HEAD(bh)->sequence = cpu_to_be32(bidx);
@@ -683,8 +678,7 @@ static int affs_write_end_ofs(struct file *file, struct address_space *mapping,
 		if (IS_ERR(bh))
 			return PTR_ERR(bh);
-			BUG();
 		memcpy(AFFS_DATA(bh) + boff, data + from, tmp);
@@ -732,8 +726,7 @@ static int affs_write_end_ofs(struct file *file, struct address_space *mapping,
 		if (IS_ERR(bh))
 			goto out;
 		tmp = min(bsize, to - from);
-		if (tmp > bsize)
-			BUG();
 		memcpy(AFFS_DATA(bh), data + from, tmp);
 		if (buffer_new(bh)) {
BtrLinux
Privacy Overview
