FRV: Eliminate NULL test and memset after alloc_bootmem
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b,
alloc_bootmem and related functions never return NULL and always return a
zeroed region of memory.  Thus a NULL test or memset after calls to these
functions is unnecessary.
 arch/frv/mm/init.c |    2 --
 1 file changed, 2 deletions(-)
This was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
expression E;
statement S;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...)
... when != E
- BUG_ON (E == NULL);
- if (E == NULL) S
expression E,E1;
... when != E
- memset(E,0,E1);
Signed-off-by: Julia Lawall
Signed-off-by: David Howells
Signed-off-by: Linus Torvalds
diff --git a/arch/frv/mm/init.c b/arch/frv/mm/init.c
index 1b851db..0708284 100644
--- a/arch/frv/mm/init.c
+++ b/arch/frv/mm/init.c
@@ -87,8 +87,6 @@ void __init paging_init(void)
 		pkmap_page_table = alloc_bootmem_pages(PAGE_SIZE);
-		memset(pkmap_page_table, 0, PAGE_SIZE);
 		pge = swapper_pg_dir + pgd_index_k(PKMAP_BASE);
 		pue = pud_offset(pge, PKMAP_BASE);
 		pme = pmd_offset(pue, PKMAP_BASE);
BtrLinux
Privacy Overview
