FRV: Convert genirq namespace
Author: Thomas Gleixner <tglx@linutronix.de>
Convert to new function names.  Converted with coccinelle.
Signed-off-by: Thomas Gleixner
Signed-off-by: David Howells
 arch/frv/kernel/irq-mb93091.c | 4 ++--
 arch/frv/kernel/irq-mb93093.c | 2 +-
 arch/frv/kernel/irq-mb93493.c | 3 ++-
 arch/frv/kernel/irq.c         | 4 ++--
 4 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/arch/frv/kernel/irq-mb93091.c b/arch/frv/kernel/irq-mb93091.c
index f007aaf..9afc2ea 100644
--- a/arch/frv/kernel/irq-mb93091.c
+++ b/arch/frv/kernel/irq-mb93091.c
@@ -146,9 +146,9 @@ void __init fpga_init(void)
 	__clr_IFR(0x0000);
 	for (irq = IRQ_BASE_FPGA + 1; irq <= IRQ_BASE_FPGA + 14; irq++)
-		set_irq_chip_and_handler(irq, &frv_fpga_pic, handle_level_irq);
+		irq_set_chip_and_handler(irq, &frv_fpga_pic, handle_level_irq);
-	set_irq_chip_and_handler(IRQ_FPGA_NMI, &frv_fpga_pic, handle_edge_irq);
+	irq_set_chip_and_handler(IRQ_FPGA_NMI, &frv_fpga_pic, handle_edge_irq);
 	/* the FPGA drives the first four external IRQ inputs on the CPU PIC */
 	setup_irq(IRQ_CPU_EXTERNAL0, &fpga_irq[0]);
diff --git a/arch/frv/kernel/irq-mb93093.c b/arch/frv/kernel/irq-mb93093.c
index c7027fba..4d4ad09 100644
--- a/arch/frv/kernel/irq-mb93093.c
+++ b/arch/frv/kernel/irq-mb93093.c
@@ -124,7 +124,7 @@ void __init fpga_init(void)
 	__clr_IFR(0x0000);
 	for (irq = IRQ_BASE_FPGA + 8; irq <= IRQ_BASE_FPGA + 10; irq++)
-		set_irq_chip_and_handler(irq, &frv_fpga_pic, handle_edge_irq);
+		irq_set_chip_and_handler(irq, &frv_fpga_pic, handle_edge_irq);
 	/* the FPGA drives external IRQ input #2 on the CPU PIC */
 	setup_irq(IRQ_CPU_EXTERNAL2, &fpga_irq[0]);
diff --git a/arch/frv/kernel/irq-mb93493.c b/arch/frv/kernel/irq-mb93493.c
index 4800f24..4d034c7 100644
--- a/arch/frv/kernel/irq-mb93493.c
+++ b/arch/frv/kernel/irq-mb93493.c
@@ -139,7 +139,8 @@ void __init mb93493_init(void)
 	int irq;
 	for (irq = IRQ_BASE_MB93493 + 0; irq <= IRQ_BASE_MB93493 + 10; irq++)
-		set_irq_chip_and_handler(irq, &frv_mb93493_pic, handle_edge_irq);
+		irq_set_chip_and_handler(irq, &frv_mb93493_pic,
+					 handle_edge_irq);
 	/* the MB93493 drives external IRQ inputs on the CPU PIC */
 	setup_irq(IRQ_CPU_MB93493_0, &mb93493_irq[0]);
diff --git a/arch/frv/kernel/irq.c b/arch/frv/kernel/irq.c
index d2365a7..a5631e9 100644
--- a/arch/frv/kernel/irq.c
+++ b/arch/frv/kernel/irq.c
@@ -156,10 +156,10 @@ void __init init_IRQ(void)
 	int level;
 	for (level = 1; level <= 14; level++)
-		set_irq_chip_and_handler(level, &frv_cpu_pic,
+		irq_set_chip_and_handler(level, &frv_cpu_pic,
 					 handle_level_irq);
-	set_irq_handler(IRQ_CPU_TIMER0, handle_edge_irq);
+	irq_set_handler(IRQ_CPU_TIMER0, handle_edge_irq);
 	/* set the trigger levels for internal interrupt sources
 	 * - timers all falling-edge
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
