frv: Convert genirq namespace
Author: Thomas Gleixner <tglx@linutronix.de>
Convert to new function names. Converted with coccinelle.
Signed-off-by: Thomas Gleixner
 arch/frv/kernel/irq-mb93091.c | 4 ++--
 arch/frv/kernel/irq-mb93093.c | 2 +-
 arch/frv/kernel/irq-mb93493.c | 3 ++-
 arch/frv/kernel/irq.c         | 4 ++--
 4 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/arch/frv/kernel/irq-mb93091.c b/arch/frv/kernel/irq-mb93091.c
index 7be23b4..372fe60 100644
--- a/arch/frv/kernel/irq-mb93091.c
+++ b/arch/frv/kernel/irq-mb93091.c
@@ -146,9 +146,9 @@ void __init fpga_init(void)
 	__clr_IFR(0x0000);
 	for (irq = IRQ_BASE_FPGA + 1; irq <= IRQ_BASE_FPGA + 14; irq++)
-		set_irq_chip_and_handler(irq, &frv_fpga_pic, handle_level_irq);
+		irq_set_chip_and_handler(irq, &frv_fpga_pic, handle_level_irq);
-	set_irq_chip_and_handler(IRQ_FPGA_NMI, &frv_fpga_pic, handle_edge_irq);
+	irq_set_chip_and_handler(IRQ_FPGA_NMI, &frv_fpga_pic, handle_edge_irq);
 	/* the FPGA drives the first four external IRQ inputs on the CPU PIC */
 	setup_irq(IRQ_CPU_EXTERNAL0, &fpga_irq[0]);
diff --git a/arch/frv/kernel/irq-mb93093.c b/arch/frv/kernel/irq-mb93093.c
index c7027fba..4d4ad09 100644
--- a/arch/frv/kernel/irq-mb93093.c
+++ b/arch/frv/kernel/irq-mb93093.c
@@ -124,7 +124,7 @@ void __init fpga_init(void)
 	__clr_IFR(0x0000);
 	for (irq = IRQ_BASE_FPGA + 8; irq <= IRQ_BASE_FPGA + 10; irq++)
-		set_irq_chip_and_handler(irq, &frv_fpga_pic, handle_edge_irq);
+		irq_set_chip_and_handler(irq, &frv_fpga_pic, handle_edge_irq);
 	/* the FPGA drives external IRQ input #2 on the CPU PIC */
 	setup_irq(IRQ_CPU_EXTERNAL2, &fpga_irq[0]);
diff --git a/arch/frv/kernel/irq-mb93493.c b/arch/frv/kernel/irq-mb93493.c
index 4800f24..4d034c7 100644
--- a/arch/frv/kernel/irq-mb93493.c
+++ b/arch/frv/kernel/irq-mb93493.c
@@ -139,7 +139,8 @@ void __init mb93493_init(void)
 	int irq;
 	for (irq = IRQ_BASE_MB93493 + 0; irq <= IRQ_BASE_MB93493 + 10; irq++)
-		set_irq_chip_and_handler(irq, &frv_mb93493_pic, handle_edge_irq);
+		irq_set_chip_and_handler(irq, &frv_mb93493_pic,
+					 handle_edge_irq);
 	/* the MB93493 drives external IRQ inputs on the CPU PIC */
 	setup_irq(IRQ_CPU_MB93493_0, &mb93493_irq[0]);
diff --git a/arch/frv/kernel/irq.c b/arch/frv/kernel/irq.c
index deaba56..3bbd2c6 100644
--- a/arch/frv/kernel/irq.c
+++ b/arch/frv/kernel/irq.c
@@ -155,10 +155,10 @@ void __init init_IRQ(void)
 	int level;
 	for (level = 1; level <= 14; level++)
-		set_irq_chip_and_handler(level, &frv_cpu_pic,
+		irq_set_chip_and_handler(level, &frv_cpu_pic,
 					 handle_level_irq);
-	set_irq_handler(IRQ_CPU_TIMER0, handle_edge_irq);
+	irq_set_handler(IRQ_CPU_TIMER0, handle_edge_irq);
 	/* set the trigger levels for internal interrupt sources
 	 * - timers all falling-edge
BtrLinux
Privacy Overview
