USB: serial: fix up bug with missing {}
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
As reported by Fengguang:
FYI, coccinelle warns about
drivers/usb/serial/usb-serial.c:1415:3-51: code aligned with following code on line 1416
vim +1415 drivers/usb/serial/usb-serial.c
1412 /* we only set the reset_resume field if the serial_driver has one */
1413 for (sd = serial_drivers; *sd; ++sd) {
1414 if ((*sd)->reset_resume)
> 1415 udriver->reset_resume = usb_serial_reset_resume;
> 1416 break;
1417 }
Reported-by: Fengguang Wu
Cc: stable [3.5]
drivers/usb/serial/usb-serial.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/serial/usb-serial.c b/drivers/usb/serial/usb-serial.c
index 011c520..483919b 100644
--- a/drivers/usb/serial/usb-serial.c
+++ b/drivers/usb/serial/usb-serial.c
@@ -1404,9 +1404,10 @@ int usb_serial_register_drivers(struct usb_serial_driver *const serial_drivers[]
- if ((*sd)->reset_resume)
+ if ((*sd)->reset_resume) {
break;
rc = usb_register(udriver); |
break;
