drivers/video/bw2.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Florian Tobias Schandinat
 drivers/video/bw2.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/bw2.c b/drivers/video/bw2.c
index 7ba74cd..6bea9a9 100644
--- a/drivers/video/bw2.c
+++ b/drivers/video/bw2.c
@@ -319,8 +319,10 @@ static int __devinit bw2_probe(struct platform_device *op)
 	info->screen_base = of_ioremap(&op->resource[0], 0,
 				       info->fix.smem_len, "bw2 ram");
-	if (!info->screen_base)
+	if (!info->screen_base) {
+		err = -ENOMEM;
 		goto out_unmap_regs;
 	bw2_blank(FB_BLANK_UNBLANK, info);
BtrLinux
