[media] drivers/media/rc/redrat3.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/rc/redrat3.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/media/rc/redrat3.c b/drivers/media/rc/redrat3.c
index 2878b0e..49731b1 100644
--- a/drivers/media/rc/redrat3.c
+++ b/drivers/media/rc/redrat3.c
@@ -1217,9 +1217,10 @@ static int __devinit redrat3_dev_probe(struct usb_interface *intf,
 	rr3->carrier = 38000;
 	rr3->rc = redrat3_init_rc_dev(rr3);
-	if (!rr3->rc)
+	if (!rr3->rc) {
+		retval = -ENOMEM;
 		goto error;
 	setup_timer(&rr3->rx_timeout, redrat3_rx_timeout, (unsigned long)rr3);
 	/* we can register the device now, as it is ready */
BtrLinux
