drivers/gpu/drm/ttm/ttm_page_alloc_dma.c: Remove useless kfree
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
                        when != e = e1
                        when != e += e1
                        when != e -= e1
                        when != ++e
                        when != --e
                        when != e++
                        when != e--
                        when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Dave Airlie
 drivers/gpu/drm/ttm/ttm_page_alloc_dma.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/gpu/drm/ttm/ttm_page_alloc_dma.c b/drivers/gpu/drm/ttm/ttm_page_alloc_dma.c
index 4f9e548..969d765 100644
--- a/drivers/gpu/drm/ttm/ttm_page_alloc_dma.c
+++ b/drivers/gpu/drm/ttm/ttm_page_alloc_dma.c
@@ -1060,7 +1060,7 @@ int ttm_dma_page_alloc_init(struct ttm_mem_global *glob, unsigned max_pages)
 	_manager = kzalloc(sizeof(*_manager), GFP_KERNEL);
 	if (!_manager)
-		goto err_manager;
+		goto err;
 	mutex_init(&_manager->lock);
 	INIT_LIST_HEAD(&_manager->pools);
@@ -1078,9 +1078,6 @@ int ttm_dma_page_alloc_init(struct ttm_mem_global *glob, unsigned max_pages)
 	ttm_dma_pool_mm_shrink_init(_manager);
 	return 0;
-err_manager:
-	kfree(_manager);
-	_manager = NULL;
 err:
 	return ret;
BtrLinux
