[media] drivers/media/tuners/mt2063.c: Removes useless kfree()
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
                        when != e = e1
                        when != e += e1
                        when != e -= e1
                        when != ++e
                        when != --e
                        when != e++
                        when != e--
                        when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/tuners/mt2063.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/media/tuners/mt2063.c b/drivers/media/tuners/mt2063.c
index 0ed9091..620c4fa 100644
--- a/drivers/media/tuners/mt2063.c
+++ b/drivers/media/tuners/mt2063.c
@@ -2249,8 +2249,8 @@ struct dvb_frontend *mt2063_attach(struct dvb_frontend *fe,
 	dprintk(2, "\n");
 	state = kzalloc(sizeof(struct mt2063_state), GFP_KERNEL);
-	if (state == NULL)
-		goto error;
+	if (!state)
+		return NULL;
 	state->config = config;
 	state->i2c = i2c;
@@ -2261,10 +2261,6 @@ struct dvb_frontend *mt2063_attach(struct dvb_frontend *fe,
 	printk(KERN_INFO "%s: Attaching MT2063\n", __func__);
 	return fe;
-error:
-	kfree(state);
-	return NULL;
 EXPORT_SYMBOL_GPL(mt2063_attach);
BtrLinux
