dm mpath: fix check for null mpio in end_io fn
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The mpio dereference should be moved below the BUG_ON NULL test
in multipath_end_io().
spatch with a semantic match was used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Alasdair G Kergon
 drivers/md/dm-mpath.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/md/dm-mpath.c b/drivers/md/dm-mpath.c
index d778563..573bd04 100644
--- a/drivers/md/dm-mpath.c
+++ b/drivers/md/dm-mpath.c
@@ -1309,13 +1309,14 @@ static int multipath_end_io(struct dm_target *ti, struct request *clone,
 	struct multipath *m = ti->private;
 	struct dm_mpath_io *mpio = map_context->ptr;
-	struct pgpath *pgpath = mpio->pgpath;
+	struct pgpath *pgpath;
 	struct path_selector *ps;
 	int r;
 	BUG_ON(!mpio);
 	r  = do_end_io(m, clone, error, mpio);
+	pgpath = mpio->pgpath;
 	if (pgpath) {
 		ps = &pgpath->pg->ps;
 		if (ps->type->end_io)
BtrLinux
