[media] drivers/media/usb/tm6000/tm6000-video.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/tm6000/tm6000-video.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/media/usb/tm6000/tm6000-video.c b/drivers/media/usb/tm6000/tm6000-video.c
index 4342cd4..f656fd7 100644
--- a/drivers/media/usb/tm6000/tm6000-video.c
+++ b/drivers/media/usb/tm6000/tm6000-video.c
@@ -1802,6 +1802,7 @@ int tm6000_v4l2_register(struct tm6000_core *dev)
 		if (!dev->radio_dev) {
 			printk(KERN_INFO "%s: can't register radio device\n",
 			       dev->name);
+			ret = -ENXIO;
 			return ret; /* FIXME release resource */
BtrLinux
