staging:rtl8188eu: Removed assignments in if statements.
Author: Chi Pham <fempsci@gmail.com>
Fixed some indentation to silence (some) checkpatch errors.
The following coccinelle script found the match:
expression E0, E1, E2;
statement S0, S1;
- if ((E1 = E2) != E)
+ E1 = E2;
+ if (E1 != E)
S1 else S2
Signed-off-by: Chi Pham
drivers/staging/rtl8188eu/core/rtw_cmd.c | 12 ++++++++----
1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_cmd.c b/drivers/staging/rtl8188eu/core/rtw_cmd.c
index 8c54881..016e55b 100644
--- a/drivers/staging/rtl8188eu/core/rtw_cmd.c
+++ b/drivers/staging/rtl8188eu/core/rtw_cmd.c
@@ -1974,13 +1974,17 @@ static void c2h_wk_callback(struct work_struct *work)
evtpriv->c2h_wk_alive = true;
while (!rtw_cbuf_empty(evtpriv->c2h_queue)) {
- if ((c2h_evt = (struct c2h_evt_hdr *)rtw_cbuf_pop(evtpriv->c2h_queue)) != NULL) {
+ c2h_evt = (struct c2h_evt_hdr *)rtw_cbuf_pop(evtpriv->c2h_queue);
+ if (c2h_evt != NULL) {
/* This C2H event is read, clear it */
c2h_evt_clear(adapter);
- } else if ((c2h_evt = (struct c2h_evt_hdr *)rtw_malloc(16)) != NULL) {
+ } else {
+ c2h_evt = (struct c2h_evt_hdr *)rtw_malloc(16);
/* This C2H event is not read, read & clear now */
- if (c2h_evt_read(adapter, (u8 *)c2h_evt) != _SUCCESS)
- continue;
+ if (c2h_evt_read(adapter, (u8 *)c2h_evt) != _SUCCESS)
+ continue;
/* Special pointer to trigger c2h_evt_clear only */ |
+ } else {
- continue;
+ continue;
