MIPS: Lasat: Replace del_timer by del_timer_sync
Use del_timer_sync to ensure that the timer is stopped on all CPUs before
the driver exists.
This change was suggested by Thomas Gleixner
(http://coccinelle.lip6.fr/)
@r@
declarer name module_exit;
identifier ex;
module_exit(ex);
identifier r.ex;
ex(...) {
- del_timer
+ del_timer_sync
Signed-off-by: Julia Lawall
Cc: kernel-janitors@vger.kernel.org
Cc: tglx@linutronix.de
Cc: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/6663/
Signed-off-by: Ralf Baechle
 arch/mips/lasat/picvue_proc.c | 2 +-
diff --git a/arch/mips/lasat/picvue_proc.c b/arch/mips/lasat/picvue_proc.c
index 638c5db..2bcd839 100644
--- a/arch/mips/lasat/picvue_proc.c
+++ b/arch/mips/lasat/picvue_proc.c
@@ -175,7 +175,7 @@ static void pvc_proc_cleanup(void)
 	remove_proc_entry("scroll", pvc_display_dir);
 	remove_proc_entry(DISPLAY_DIR_NAME, NULL);
-	del_timer(&timer);
+	del_timer_sync(&timer);
 static int __init pvc_proc_init(void)
BtrLinux
