drm: Replace crtc fb with primary plane fb (v3)
Author: Matt Roper <matthew.d.roper@intel.com>
Now that CRTC's have a primary plane, there's no need to track the
framebuffer in the CRTC.  Replace all references to the CRTC fb with the
primary plane's fb.
This patch was generated by the Coccinelle semantic patching tool using
the following rules:
        @@ struct drm_crtc C; @@
        -   (C).fb
        +   C.primary->fb
        @@ struct drm_crtc *C; @@
        -   (C)->fb
        +   C->primary->fb
v3: Generate patch via coccinelle.  Actual removal of crtc->fb has been
    moved to a subsequent patch.
v2: Fixup several lingering crtc->fb instances that were missed in the
    first patch iteration.  [Rob Clark]
Signed-off-by: Matt Roper
Reviewed-by: Rob Clark
 drivers/gpu/drm/armada/armada_crtc.c         | 23 ++++++------
 drivers/gpu/drm/ast/ast_mode.c               | 12 +++----
 drivers/gpu/drm/bochs/bochs_kms.c            |  4 +--
 drivers/gpu/drm/cirrus/cirrus_mode.c         | 10 +++---
 drivers/gpu/drm/drm_crtc.c                   | 26 +++++++-------
 drivers/gpu/drm/drm_crtc_helper.c            | 20 +++++------
 drivers/gpu/drm/drm_fb_helper.c              |  6 ++--
 drivers/gpu/drm/exynos/exynos_drm_crtc.c     | 20 +++++------
 drivers/gpu/drm/gma500/cdv_intel_display.c   |  2 +-
 drivers/gpu/drm/gma500/cdv_intel_dp.c        |  2 +-
 drivers/gpu/drm/gma500/cdv_intel_hdmi.c      |  2 +-
 drivers/gpu/drm/gma500/cdv_intel_lvds.c      |  2 +-
 drivers/gpu/drm/gma500/gma_display.c         | 16 ++++-----
 drivers/gpu/drm/gma500/mdfld_dsi_output.c    |  2 +-
 drivers/gpu/drm/gma500/mdfld_intel_display.c | 16 ++++-----
 drivers/gpu/drm/gma500/oaktrail_crtc.c       | 12 +++----
 drivers/gpu/drm/gma500/psb_intel_display.c   |  2 +-
 drivers/gpu/drm/gma500/psb_intel_lvds.c      |  2 +-
 drivers/gpu/drm/gma500/psb_intel_sdvo.c      |  2 +-
 drivers/gpu/drm/i915/i915_debugfs.c          |  4 +--
 drivers/gpu/drm/i915/i915_irq.c              |  4 +--
 drivers/gpu/drm/i915/intel_display.c         | 52 ++++++++++++++--------------
 drivers/gpu/drm/i915/intel_dp.c              |  4 +--
 drivers/gpu/drm/i915/intel_overlay.c         |  4 +--
 drivers/gpu/drm/i915/intel_pm.c              | 36 +++++++++----------
 drivers/gpu/drm/mgag200/mgag200_mode.c       | 26 +++++++-------
 drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c     | 28 +++++++--------
 drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c     | 22 ++++++------
 drivers/gpu/drm/nouveau/dispnv04/crtc.c      | 20 +++++------
 drivers/gpu/drm/nouveau/dispnv04/dfp.c       |  2 +-
 drivers/gpu/drm/nouveau/nouveau_display.c    |  8 ++---
 drivers/gpu/drm/nouveau/nv50_display.c       | 17 ++++-----
 drivers/gpu/drm/omapdrm/omap_crtc.c          | 13 +++----
 drivers/gpu/drm/omapdrm/omap_fb.c            |  2 +-
 drivers/gpu/drm/qxl/qxl_display.c            | 10 +++---
 drivers/gpu/drm/radeon/atombios_crtc.c       | 20 +++++------
 drivers/gpu/drm/radeon/r100.c                |  4 +--
 drivers/gpu/drm/radeon/radeon_connectors.c   |  2 +-
 drivers/gpu/drm/radeon/radeon_device.c       |  2 +-
 drivers/gpu/drm/radeon/radeon_display.c      |  4 +--
 drivers/gpu/drm/radeon/radeon_legacy_crtc.c  | 16 ++++-----
 drivers/gpu/drm/rcar-du/rcar_du_crtc.c       | 10 +++---
 drivers/gpu/drm/shmobile/shmob_drm_crtc.c    | 14 ++++----
 drivers/gpu/drm/tegra/dc.c                   | 16 ++++-----
 drivers/gpu/drm/tilcdc/tilcdc_crtc.c         |  8 ++---
 drivers/gpu/drm/udl/udl_modeset.c            |  2 +-
 drivers/gpu/drm/vmwgfx/vmwgfx_kms.c          | 14 ++++----
 drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c          |  8 ++---
 drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c         |  8 ++---
 drivers/staging/imx-drm/ipuv3-crtc.c         |  6 ++--
 50 files changed, 285 insertions(+), 282 deletions(-)
diff --git a/drivers/gpu/drm/armada/armada_crtc.c b/drivers/gpu/drm/armada/armada_crtc.c
index d8e3982..5831e41 100644
--- a/drivers/gpu/drm/armada/armada_crtc.c
+++ b/drivers/gpu/drm/armada/armada_crtc.c
@@ -478,11 +478,12 @@ static int armada_drm_crtc_mode_set(struct drm_crtc *crtc,
 	unsigned i;
 	bool interlaced;
-	drm_framebuffer_reference(crtc->fb);
+	drm_framebuffer_reference(crtc->primary->fb);
 	interlaced = !!(adj->flags & DRM_MODE_FLAG_INTERLACE);
-	i = armada_drm_crtc_calc_fb(dcrtc->crtc.fb, x, y, regs, interlaced);
+	i = armada_drm_crtc_calc_fb(dcrtc->crtc.primary->fb,
+				    x, y, regs, interlaced);
 	rm = adj->crtc_hsync_start - adj->crtc_hdisplay;
 	lm = adj->crtc_htotal - adj->crtc_hsync_end;
@@ -567,10 +568,10 @@ static int armada_drm_crtc_mode_set(struct drm_crtc *crtc,
 	val = CFG_GRA_ENA | CFG_GRA_HSMOOTH;
-	val |= CFG_GRA_FMT(drm_fb_to_armada_fb(dcrtc->crtc.fb)->fmt);
-	val |= CFG_GRA_MOD(drm_fb_to_armada_fb(dcrtc->crtc.fb)->mod);
+	val |= CFG_GRA_FMT(drm_fb_to_armada_fb(dcrtc->crtc.primary->fb)->fmt);
+	val |= CFG_GRA_MOD(drm_fb_to_armada_fb(dcrtc->crtc.primary->fb)->mod);
-	if (drm_fb_to_armada_fb(dcrtc->crtc.fb)->fmt > CFG_420)
+	if (drm_fb_to_armada_fb(dcrtc->crtc.primary->fb)->fmt > CFG_420)
 		val |= CFG_PALETTE_ENA;
 	if (interlaced)
@@ -608,7 +609,7 @@ static int armada_drm_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 	struct armada_regs regs[4];
 	unsigned i;
-	i = armada_drm_crtc_calc_fb(crtc->fb, crtc->x, crtc->y, regs,
+	i = armada_drm_crtc_calc_fb(crtc->primary->fb, crtc->x, crtc->y, regs,
 				    dcrtc->interlaced);
 	armada_reg_queue_end(regs, i);
@@ -616,7 +617,7 @@ static int armada_drm_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 	wait_event(dcrtc->frame_wait, !dcrtc->frame_work);
 	/* Take a reference to the new fb as we're using it */
 	/* Update the base in the CRTC */
 	armada_drm_crtc_update_regs(dcrtc, regs);
@@ -637,7 +638,7 @@ static void armada_drm_crtc_disable(struct drm_crtc *crtc)
 	struct armada_crtc *dcrtc = drm_to_armada_crtc(crtc);
 	armada_drm_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
-	armada_drm_crtc_finish_fb(dcrtc, crtc->fb, true);
+	armada_drm_crtc_finish_fb(dcrtc, crtc->primary->fb, true);
 	/* Power down most RAMs and FIFOs */
 	writel_relaxed(CFG_PDWN256x32 | CFG_PDWN256x24 | CFG_PDWN256x8 |
@@ -904,7 +905,7 @@ static int armada_drm_crtc_page_flip(struct drm_crtc *crtc,
 	int ret;
 	/* We don't support changing the pixel format */
-	if (fb->pixel_format != crtc->fb->pixel_format)
+	if (fb->pixel_format != crtc->primary->fb->pixel_format)
 		return -EINVAL;
 	work = kmalloc(sizeof(*work), GFP_KERNEL);
@@ -912,7 +913,7 @@ static int armada_drm_crtc_page_flip(struct drm_crtc *crtc,
 		return -ENOMEM;
 	work->event = event;
-	work->old_fb = dcrtc->crtc.fb;
+	work->old_fb = dcrtc->crtc.primary->fb;
 	i = armada_drm_crtc_calc_fb(fb, crtc->x, crtc->y, work->regs,
 				    dcrtc->interlaced);
@@ -941,7 +942,7 @@ static int armada_drm_crtc_page_flip(struct drm_crtc *crtc,
 	 * will _not_ drop that reference on successful return from this
 	 * function.  Simply mark this new framebuffer as the current one.
-	dcrtc->crtc.fb = fb;
+	dcrtc->crtc.primary->fb = fb;
 	 * Finally, if the display is blanked, we won't receive an
diff --git a/drivers/gpu/drm/ast/ast_mode.c b/drivers/gpu/drm/ast/ast_mode.c
index cca063b..a4afdc8 100644
--- a/drivers/gpu/drm/ast/ast_mode.c
+++ b/drivers/gpu/drm/ast/ast_mode.c
@@ -81,7 +81,7 @@ static bool ast_get_vbios_mode_info(struct drm_crtc *crtc, struct drm_display_mo
 	u32 refresh_rate_index = 0, mode_id, color_index, refresh_rate;
 	u32 hborder, vborder;
-	switch (crtc->fb->bits_per_pixel) {
+	switch (crtc->primary->fb->bits_per_pixel) {
 	case 8:
 		vbios_mode->std_table = &vbios_stdtable[VGAModeIndex];
 		color_index = VGAModeIndex - 1;
@@ -176,7 +176,7 @@ static bool ast_get_vbios_mode_info(struct drm_crtc *crtc, struct drm_display_mo
 		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x8e, mode_id & 0xff);
 		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x91, 0xa8);
-		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x92, crtc->fb->bits_per_pixel);
+		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x92, crtc->primary->fb->bits_per_pixel);
 		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x93, adjusted_mode->clock / 1000);
 		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x94, adjusted_mode->crtc_hdisplay);
 		ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x95, adjusted_mode->crtc_hdisplay >> 8);
@@ -340,7 +340,7 @@ static void ast_set_offset_reg(struct drm_crtc *crtc)
 	u16 offset;
-	offset = crtc->fb->pitches[0] >> 3;
+	offset = crtc->primary->fb->pitches[0] >> 3;
 	ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x13, (offset & 0xff));
 	ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0xb0, (offset >> 8) & 0x3f);
@@ -365,7 +365,7 @@ static void ast_set_ext_reg(struct drm_crtc *crtc, struct drm_display_mode *mode
 	struct ast_private *ast = crtc->dev->dev_private;
 	u8 jregA0 = 0, jregA3 = 0, jregA8 = 0;
 	case 8:
 		jregA0 = 0x70;
 		jregA3 = 0x01;
@@ -418,7 +418,7 @@ static void ast_set_sync_reg(struct drm_device *dev, struct drm_display_mode *mo
 static bool ast_set_dac_reg(struct drm_crtc *crtc, struct drm_display_mode *mode,
 		     struct ast_vbios_mode_info *vbios_mode)
 	case 8:
 		break;
 	default:
@@ -490,7 +490,7 @@ static int ast_crtc_do_set_base(struct drm_crtc *crtc,
 		ast_bo_unreserve(bo);
-	ast_fb = to_ast_framebuffer(crtc->fb);
+	ast_fb = to_ast_framebuffer(crtc->primary->fb);
 	obj = ast_fb->obj;
 	bo = gem_to_ast_bo(obj);
diff --git a/drivers/gpu/drm/bochs/bochs_kms.c b/drivers/gpu/drm/bochs/bochs_kms.c
index 62ec7d4..dcf2e55 100644
--- a/drivers/gpu/drm/bochs/bochs_kms.c
+++ b/drivers/gpu/drm/bochs/bochs_kms.c
@@ -62,10 +62,10 @@ static int bochs_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
-	if (WARN_ON(crtc->fb == NULL))
+	if (WARN_ON(crtc->primary->fb == NULL))
 		return -EINVAL;
-	bochs_fb = to_bochs_framebuffer(crtc->fb);
+	bochs_fb = to_bochs_framebuffer(crtc->primary->fb);
 	bo = gem_to_bochs_bo(bochs_fb->obj);
 	ret = ttm_bo_reserve(&bo->bo, true, false, false, 0);
 	if (ret)
diff --git a/drivers/gpu/drm/cirrus/cirrus_mode.c b/drivers/gpu/drm/cirrus/cirrus_mode.c
index 530f78f..2d64aea 100644
--- a/drivers/gpu/drm/cirrus/cirrus_mode.c
+++ b/drivers/gpu/drm/cirrus/cirrus_mode.c
@@ -149,7 +149,7 @@ static int cirrus_crtc_do_set_base(struct drm_crtc *crtc,
 		cirrus_bo_unreserve(bo);
-	cirrus_fb = to_cirrus_framebuffer(crtc->fb);
+	cirrus_fb = to_cirrus_framebuffer(crtc->primary->fb);
 	obj = cirrus_fb->obj;
 	bo = gem_to_cirrus_bo(obj);
@@ -268,7 +268,7 @@ static int cirrus_crtc_mode_set(struct drm_crtc *crtc,
 	sr07 = RREG8(SEQ_DATA);
 	sr07 &= 0xe0;
 	hdr = 0;
 	case 8:
 		sr07 |= 0x11;
 		break;
@@ -291,13 +291,13 @@ static int cirrus_crtc_mode_set(struct drm_crtc *crtc,
 	WREG_SEQ(0x7, sr07);
 	/* Program the pitch */
-	tmp = crtc->fb->pitches[0] / 8;
+	tmp = crtc->primary->fb->pitches[0] / 8;
 	WREG_CRT(VGA_CRTC_OFFSET, tmp);
 	/* Enable extended blanking and pitch bits, and enable full memory */
 	tmp = 0x22;
-	tmp |= (crtc->fb->pitches[0] >> 7) & 0x10;
-	tmp |= (crtc->fb->pitches[0] >> 6) & 0x40;
+	tmp |= (crtc->primary->fb->pitches[0] >> 7) & 0x10;
+	tmp |= (crtc->primary->fb->pitches[0] >> 6) & 0x40;
 	WREG_CRT(0x1b, tmp);
 	/* Enable high-colour modes */
diff --git a/drivers/gpu/drm/drm_crtc.c b/drivers/gpu/drm/drm_crtc.c
index 110e5ce..18321fb 100644
--- a/drivers/gpu/drm/drm_crtc.c
+++ b/drivers/gpu/drm/drm_crtc.c
@@ -669,7 +669,7 @@ void drm_framebuffer_remove(struct drm_framebuffer *fb)
 		drm_modeset_lock_all(dev);
 		/* remove from any CRTC */
 		list_for_each_entry(crtc, &dev->mode_config.crtc_list, head) {
-			if (crtc->fb == fb) {
+			if (crtc->primary->fb == fb) {
 				/* should turn off the crtc */
 				memset(&set, 0, sizeof(struct drm_mode_set));
 				set.crtc = crtc;
@@ -1714,8 +1714,8 @@ int drm_mode_getcrtc(struct drm_device *dev,
 	crtc_resp->x = crtc->x;
 	crtc_resp->y = crtc->y;
 	crtc_resp->gamma_size = crtc->gamma_size;
-	if (crtc->fb)
-		crtc_resp->fb_id = crtc->fb->base.id;
+	if (crtc->primary->fb)
+		crtc_resp->fb_id = crtc->primary->fb->base.id;
 	else
 		crtc_resp->fb_id = 0;
@@ -2222,7 +2222,7 @@ int drm_mode_set_config_internal(struct drm_mode_set *set)
 	 * crtcs. Atomic modeset will have saner semantics ...
 	list_for_each_entry(tmp, &crtc->dev->mode_config.crtc_list, head)
-		tmp->old_fb = tmp->fb;
+		tmp->old_fb = tmp->primary->fb;
 	fb = set->fb;
@@ -2231,12 +2231,12 @@ int drm_mode_set_config_internal(struct drm_mode_set *set)
 		crtc->primary->crtc = crtc;
 		/* crtc->fb must be updated by ->set_config, enforces this. */
-		WARN_ON(fb != crtc->fb);
+		WARN_ON(fb != crtc->primary->fb);
 	list_for_each_entry(tmp, &crtc->dev->mode_config.crtc_list, head) {
-		if (tmp->fb)
-			drm_framebuffer_reference(tmp->fb);
+		if (tmp->primary->fb)
+			drm_framebuffer_reference(tmp->primary->fb);
 		if (tmp->old_fb)
 			drm_framebuffer_unreference(tmp->old_fb);
@@ -2340,12 +2340,12 @@ int drm_mode_setcrtc(struct drm_device *dev, void *data,
 		/* If we have a mode we need a framebuffer. */
 		/* If we pass -1, set the mode with the currently bound fb */
 		if (crtc_req->fb_id == -1) {
-			if (!crtc->fb) {
+			if (!crtc->primary->fb) {
 				DRM_DEBUG_KMS("CRTC doesn't have current FB\n");
 				ret = -EINVAL;
 				goto out;
-			fb = crtc->fb;
+			fb = crtc->primary->fb;
 			/* Make refcounting symmetric with the lookup path. */
 			drm_framebuffer_reference(fb);
 		} else {
@@ -4139,7 +4139,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
 	crtc = obj_to_crtc(obj);
 	mutex_lock(&crtc->mutex);
-	if (crtc->fb == NULL) {
+	if (crtc->primary->fb == NULL) {
 		/* The framebuffer is currently unbound, presumably
 		 * due to a hotplug event, that userspace has not
 		 * yet discovered.
@@ -4161,7 +4161,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
 	if (ret)
 		goto out;
-	if (crtc->fb->pixel_format != fb->pixel_format) {
+	if (crtc->primary->fb->pixel_format != fb->pixel_format) {
 		DRM_DEBUG_KMS("Page flip is not allowed to change frame buffer format.\n");
 		ret = -EINVAL;
 		goto out;
@@ -4194,7 +4194,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
 			(void (*) (struct drm_pending_event *)) kfree;
-	old_fb = crtc->fb;
+	old_fb = crtc->primary->fb;
 	ret = crtc->funcs->page_flip(crtc, fb, e, page_flip->flags);
 	if (ret) {
 		if (page_flip->flags & DRM_MODE_PAGE_FLIP_EVENT) {
@@ -4212,7 +4212,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
 		 * Failing to do so will screw with the reference counting
 		 * on framebuffers.
-		WARN_ON(crtc->fb != fb);
+		WARN_ON(crtc->primary->fb != fb);
 		/* Unref only the old framebuffer. */
 		fb = NULL;
diff --git a/drivers/gpu/drm/drm_crtc_helper.c b/drivers/gpu/drm/drm_crtc_helper.c
index c0f2d62..2dd806b 100644
--- a/drivers/gpu/drm/drm_crtc_helper.c
+++ b/drivers/gpu/drm/drm_crtc_helper.c
@@ -309,7 +309,7 @@ static void __drm_helper_disable_unused_functions(struct drm_device *dev)
 				(*crtc_funcs->disable)(crtc);
 			else
 				(*crtc_funcs->dpms)(crtc, DRM_MODE_DPMS_OFF);
-			crtc->fb = NULL;
+			crtc->primary->fb = NULL;
@@ -653,19 +653,19 @@ int drm_crtc_helper_set_config(struct drm_mode_set *set)
 	save_set.mode = &set->crtc->mode;
 	save_set.x = set->crtc->x;
 	save_set.y = set->crtc->y;
-	save_set.fb = set->crtc->fb;
+	save_set.fb = set->crtc->primary->fb;
 	/* We should be able to check here if the fb has the same properties
 	 * and then just flip_or_move it */
-	if (set->crtc->fb != set->fb) {
+	if (set->crtc->primary->fb != set->fb) {
 		/* If we have no fb then treat it as a full mode set */
-		if (set->crtc->fb == NULL) {
+		if (set->crtc->primary->fb == NULL) {
 			DRM_DEBUG_KMS("crtc has no fb, full mode set\n");
 			mode_changed = true;
 		} else if (set->fb == NULL) {
 		} else if (set->fb->pixel_format !=
-			   set->crtc->fb->pixel_format) {
+			   set->crtc->primary->fb->pixel_format) {
 		} else
 			fb_changed = true;
@@ -766,13 +766,13 @@ int drm_crtc_helper_set_config(struct drm_mode_set *set)
 			DRM_DEBUG_KMS("attempting to set mode from"
 					" userspace\n");
 			drm_mode_debug_printmodeline(set->mode);
-			set->crtc->fb = set->fb;
+			set->crtc->primary->fb = set->fb;
 			if (!drm_crtc_helper_set_mode(set->crtc, set->mode,
 						      set->x, set->y,
 						      save_set.fb)) {
 				DRM_ERROR("failed to set mode on [CRTC:%d]\n",
 					  set->crtc->base.id);
-				set->crtc->fb = save_set.fb;
+				set->crtc->primary->fb = save_set.fb;
 				ret = -EINVAL;
 				goto fail;
@@ -787,13 +787,13 @@ int drm_crtc_helper_set_config(struct drm_mode_set *set)
 	} else if (fb_changed) {
 		set->crtc->x = set->x;
 		set->crtc->y = set->y;
 		ret = crtc_funcs->mode_set_base(set->crtc,
 						set->x, set->y, save_set.fb);
 		if (ret != 0) {
 			set->crtc->x = save_set.x;
 			set->crtc->y = save_set.y;
 			goto fail;
@@ -990,7 +990,7 @@ void drm_helper_resume_force_mode(struct drm_device *dev)
 			continue;
 		ret = drm_crtc_helper_set_mode(crtc, &crtc->mode,
-					       crtc->x, crtc->y, crtc->fb);
+					       crtc->x, crtc->y, crtc->primary->fb);
 		/* Restoring the old config should never fail! */
 		if (ret == false)
diff --git a/drivers/gpu/drm/drm_fb_helper.c b/drivers/gpu/drm/drm_fb_helper.c
index f30bf7b..9795c06 100644
--- a/drivers/gpu/drm/drm_fb_helper.c
+++ b/drivers/gpu/drm/drm_fb_helper.c
@@ -232,7 +232,7 @@ static struct drm_framebuffer *drm_mode_config_fb(struct drm_crtc *crtc)
 	list_for_each_entry(c, &dev->mode_config.crtc_list, head) {
 		if (crtc->base.id == c->base.id)
-			return c->fb;
+			return c->primary->fb;
 	return NULL;
@@ -366,9 +366,9 @@ static bool drm_fb_helper_is_bound(struct drm_fb_helper *fb_helper)
 		return false;
-		if (crtc->fb)
 			crtcs_bound++;
-		if (crtc->fb == fb_helper->fb)
+		if (crtc->primary->fb == fb_helper->fb)
 			bound++;
diff --git a/drivers/gpu/drm/exynos/exynos_drm_crtc.c b/drivers/gpu/drm/exynos/exynos_drm_crtc.c
index 5c9afa1..e930d4f 100644
--- a/drivers/gpu/drm/exynos/exynos_drm_crtc.c
+++ b/drivers/gpu/drm/exynos/exynos_drm_crtc.c
@@ -132,19 +132,19 @@ exynos_drm_crtc_mode_set(struct drm_crtc *crtc, struct drm_display_mode *mode,
 	memcpy(&crtc->mode, adjusted_mode, sizeof(*adjusted_mode));
-	crtc_w = crtc->fb->width - x;
-	crtc_h = crtc->fb->height - y;
+	crtc_w = crtc->primary->fb->width - x;
+	crtc_h = crtc->primary->fb->height - y;
 	if (manager->ops->mode_set)
 		manager->ops->mode_set(manager, &crtc->mode);
-	ret = exynos_plane_mode_set(plane, crtc, crtc->fb, 0, 0, crtc_w, crtc_h,
+	ret = exynos_plane_mode_set(plane, crtc, crtc->primary->fb, 0, 0, crtc_w, crtc_h,
 				    x, y, crtc_w, crtc_h);
 	if (ret)
 		return ret;
 	plane->crtc = crtc;
-	plane->fb = crtc->fb;
+	plane->fb = crtc->primary->fb;
 	return 0;
@@ -164,10 +164,10 @@ static int exynos_drm_crtc_mode_set_commit(struct drm_crtc *crtc, int x, int y,
 		return -EPERM;
 	if (ret)
 		return ret;
@@ -218,7 +218,7 @@ static int exynos_drm_crtc_page_flip(struct drm_crtc *crtc,
 	struct drm_device *dev = crtc->dev;
 	struct exynos_drm_private *dev_priv = dev->dev_private;
 	struct exynos_drm_crtc *exynos_crtc = to_exynos_crtc(crtc);
-	struct drm_framebuffer *old_fb = crtc->fb;
+	struct drm_framebuffer *old_fb = crtc->primary->fb;
 	int ret = -EINVAL;
 	/* when the page flip is requested, crtc's dpms should be on */
@@ -249,11 +249,11 @@ static int exynos_drm_crtc_page_flip(struct drm_crtc *crtc,
 		atomic_set(&exynos_crtc->pending_flip, 1);
 		spin_unlock_irq(&dev->event_lock);
-		crtc->fb = fb;
+		crtc->primary->fb = fb;
 		ret = exynos_drm_crtc_mode_set_commit(crtc, crtc->x, crtc->y,
 						    NULL);
 		if (ret) {
-			crtc->fb = old_fb;
+			crtc->primary->fb = old_fb;
 			spin_lock_irq(&dev->event_lock);
 			drm_vblank_put(dev, exynos_crtc->pipe);
diff --git a/drivers/gpu/drm/gma500/cdv_intel_display.c b/drivers/gpu/drm/gma500/cdv_intel_display.c
index 7ff91ce..6672732 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_display.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_display.c
@@ -469,7 +469,7 @@ static bool cdv_intel_pipe_enabled(struct drm_device *dev, int pipe)
 	crtc = dev_priv->pipe_to_crtc_mapping[pipe];
 	gma_crtc = to_gma_crtc(crtc);
-	if (crtc->fb == NULL || !gma_crtc->active)
+	if (crtc->primary->fb == NULL || !gma_crtc->active)
 		return false;
 	return true;
diff --git a/drivers/gpu/drm/gma500/cdv_intel_dp.c b/drivers/gpu/drm/gma500/cdv_intel_dp.c
index 0490ce3..9ff30c2 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_dp.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_dp.c
@@ -1693,7 +1693,7 @@ done:
 		struct drm_crtc *crtc = encoder->base.crtc;
 					 crtc->x, crtc->y,
-					 crtc->fb);
+					 crtc->primary->fb);
 	return 0;
diff --git a/drivers/gpu/drm/gma500/cdv_intel_hdmi.c b/drivers/gpu/drm/gma500/cdv_intel_hdmi.c
index 968b42a..b99084b 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_hdmi.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_hdmi.c
@@ -192,7 +192,7 @@ static int cdv_hdmi_set_property(struct drm_connector *connector,
 		    crtc->saved_mode.vdisplay != 0) {
 			if (centre) {
 				if (!drm_crtc_helper_set_mode(encoder->crtc, &crtc->saved_mode,
-					    encoder->crtc->x, encoder->crtc->y, encoder->crtc->fb))
+					    encoder->crtc->x, encoder->crtc->y, encoder->crtc->primary->fb))
 					return -1;
 			} else {
 				struct drm_encoder_helper_funcs *helpers
diff --git a/drivers/gpu/drm/gma500/cdv_intel_lvds.c b/drivers/gpu/drm/gma500/cdv_intel_lvds.c
index 66a41c0..8ecc920 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_lvds.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_lvds.c
@@ -494,7 +494,7 @@ static int cdv_intel_lvds_set_property(struct drm_connector *connector,
 						      &crtc->saved_mode,
 						      encoder->crtc->x,
 						      encoder->crtc->y,
-						      encoder->crtc->fb))
+						      encoder->crtc->primary->fb))
 				return -1;
 	} else if (!strcmp(property->name, "backlight") && encoder) {
diff --git a/drivers/gpu/drm/gma500/gma_display.c b/drivers/gpu/drm/gma500/gma_display.c
index d45476b..9bb9bdd 100644
--- a/drivers/gpu/drm/gma500/gma_display.c
+++ b/drivers/gpu/drm/gma500/gma_display.c
@@ -59,7 +59,7 @@ int gma_pipe_set_base(struct drm_crtc *crtc, int x, int y,
 	struct drm_psb_private *dev_priv = dev->dev_private;
 	struct gma_crtc *gma_crtc = to_gma_crtc(crtc);
-	struct psb_framebuffer *psbfb = to_psb_fb(crtc->fb);
+	struct psb_framebuffer *psbfb = to_psb_fb(crtc->primary->fb);
 	int pipe = gma_crtc->pipe;
 	const struct psb_offset *map = &dev_priv->regmap[pipe];
 	unsigned long start, offset;
@@ -70,7 +70,7 @@ int gma_pipe_set_base(struct drm_crtc *crtc, int x, int y,
 		return 0;
 	/* no fb bound */
-	if (!crtc->fb) {
 		dev_err(dev->dev, "No FB bound\n");
 		goto gma_pipe_cleaner;
@@ -81,19 +81,19 @@ int gma_pipe_set_base(struct drm_crtc *crtc, int x, int y,
 	if (ret < 0)
 		goto gma_pipe_set_base_exit;
 	start = psbfb->gtt->offset;
-	offset = y * crtc->fb->pitches[0] + x * (crtc->fb->bits_per_pixel / 8);
+	offset = y * crtc->primary->fb->pitches[0] + x * (crtc->primary->fb->bits_per_pixel / 8);
-	REG_WRITE(map->stride, crtc->fb->pitches[0]);
+	REG_WRITE(map->stride, crtc->primary->fb->pitches[0]);
 	dspcntr = REG_READ(map->cntr);
 	dspcntr &= ~DISPPLANE_PIXFORMAT_MASK;
 	case 8:
 		dspcntr |= DISPPLANE_8BPP;
 		break;
 	case 16:
-		if (crtc->fb->depth == 15)
+		if (crtc->primary->fb->depth == 15)
 			dspcntr |= DISPPLANE_15_16BPP;
 		else
 			dspcntr |= DISPPLANE_16BPP;
@@ -518,8 +518,8 @@ void gma_crtc_disable(struct drm_crtc *crtc)
 	crtc_funcs->dpms(crtc, DRM_MODE_DPMS_OFF);
-	if (crtc->fb) {
-		gt = to_psb_fb(crtc->fb)->gtt;
+	if (crtc->primary->fb) {
+		gt = to_psb_fb(crtc->primary->fb)->gtt;
 		psb_gtt_unpin(gt);
diff --git a/drivers/gpu/drm/gma500/mdfld_dsi_output.c b/drivers/gpu/drm/gma500/mdfld_dsi_output.c
index 860a4ee..6e91b20 100644
--- a/drivers/gpu/drm/gma500/mdfld_dsi_output.c
+++ b/drivers/gpu/drm/gma500/mdfld_dsi_output.c
@@ -287,7 +287,7 @@ static int mdfld_dsi_connector_set_property(struct drm_connector *connector,
 						&gma_crtc->saved_mode,
 						encoder->crtc->x,
 						encoder->crtc->y,
 					goto set_prop_error;
 			} else {
 				struct drm_encoder_helper_funcs *funcs =
diff --git a/drivers/gpu/drm/gma500/mdfld_intel_display.c b/drivers/gpu/drm/gma500/mdfld_intel_display.c
index 321c00a..8cc8a5a 100644
--- a/drivers/gpu/drm/gma500/mdfld_intel_display.c
+++ b/drivers/gpu/drm/gma500/mdfld_intel_display.c
@@ -166,7 +166,7 @@ static int mdfld__intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
@@ -178,12 +178,12 @@ static int mdfld__intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
 	dev_dbg(dev->dev, "pipe = 0x%x.\n", pipe);
 	/* no fb bound */
-	if (!crtc->fb) {
 		dev_dbg(dev->dev, "No FB bound\n");
 		return 0;
-	ret = check_fb(crtc->fb);
+	ret = check_fb(crtc->primary->fb);
 	if (ret)
 		return ret;
@@ -196,18 +196,18 @@ static int mdfld__intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
 		return 0;
 	case 8:
 		break;
 	case 16:
 		else
@@ -700,7 +700,7 @@ static int mdfld_crtc_mode_set(struct drm_crtc *crtc,
 #endif
 	if (ret)
 		return ret;
diff --git a/drivers/gpu/drm/gma500/oaktrail_crtc.c b/drivers/gpu/drm/gma500/oaktrail_crtc.c
index 8195e85..2de216c 100644
--- a/drivers/gpu/drm/gma500/oaktrail_crtc.c
+++ b/drivers/gpu/drm/gma500/oaktrail_crtc.c
@@ -599,7 +599,7 @@ static int oaktrail_pipe_set_base(struct drm_crtc *crtc,
@@ -608,7 +608,7 @@ static int oaktrail_pipe_set_base(struct drm_crtc *crtc,
 	int ret = 0;
 	/* no fb bound */
-	if (!crtc->fb) {
 		return 0;
@@ -617,19 +617,19 @@ static int oaktrail_pipe_set_base(struct drm_crtc *crtc,
 		return 0;
 	case 8:
 		break;
 	case 16:
 		else
diff --git a/drivers/gpu/drm/gma500/psb_intel_display.c b/drivers/gpu/drm/gma500/psb_intel_display.c
index 21aed85..87b50ba 100644
--- a/drivers/gpu/drm/gma500/psb_intel_display.c
+++ b/drivers/gpu/drm/gma500/psb_intel_display.c
@@ -120,7 +120,7 @@ static int psb_intel_crtc_mode_set(struct drm_crtc *crtc,
 	const struct gma_limit_t *limit;
 	/* No scan out no play */
 		crtc_funcs->mode_set_base(crtc, x, y, old_fb);
 		return 0;
diff --git a/drivers/gpu/drm/gma500/psb_intel_lvds.c b/drivers/gpu/drm/gma500/psb_intel_lvds.c
index 891a028..d7778d0 100644
--- a/drivers/gpu/drm/gma500/psb_intel_lvds.c
+++ b/drivers/gpu/drm/gma500/psb_intel_lvds.c
@@ -614,7 +614,7 @@ int psb_intel_lvds_set_property(struct drm_connector *connector,
 						      &crtc->saved_mode,
 						      encoder->crtc->x,
 						      encoder->crtc->y,
 	} else if (!strcmp(property->name, "backlight")) {
diff --git a/drivers/gpu/drm/gma500/psb_intel_sdvo.c b/drivers/gpu/drm/gma500/psb_intel_sdvo.c
index 681efec..deeb082 100644
--- a/drivers/gpu/drm/gma500/psb_intel_sdvo.c
+++ b/drivers/gpu/drm/gma500/psb_intel_sdvo.c
@@ -1844,7 +1844,7 @@ done:
 	if (psb_intel_sdvo->base.base.crtc) {
 		struct drm_crtc *crtc = psb_intel_sdvo->base.base.crtc;
 		drm_crtc_helper_set_mode(crtc, &crtc->mode, crtc->x,
-					 crtc->y, crtc->fb);
+					 crtc->y, crtc->primary->fb);
 	return 0;
diff --git a/drivers/gpu/drm/i915/i915_debugfs.c b/drivers/gpu/drm/i915/i915_debugfs.c
index a90d31c..cacd497 100644
--- a/drivers/gpu/drm/i915/i915_debugfs.c
+++ b/drivers/gpu/drm/i915/i915_debugfs.c
@@ -2172,8 +2172,8 @@ static void intel_crtc_info(struct seq_file *m, struct intel_crtc *intel_crtc)
 	struct intel_encoder *intel_encoder;
 	seq_printf(m, "\tfb: %d, pos: %dx%d, size: %dx%d\n",
-		   crtc->fb->base.id, crtc->x, crtc->y,
-		   crtc->fb->width, crtc->fb->height);
+		   crtc->primary->fb->base.id, crtc->x, crtc->y,
+		   crtc->primary->fb->width, crtc->primary->fb->height);
 	for_each_encoder_on_crtc(dev, crtc, intel_encoder)
 		intel_encoder_info(m, intel_crtc, intel_encoder);
diff --git a/drivers/gpu/drm/i915/i915_irq.c b/drivers/gpu/drm/i915/i915_irq.c
index be2713f..15d5e61 100644
--- a/drivers/gpu/drm/i915/i915_irq.c
+++ b/drivers/gpu/drm/i915/i915_irq.c
@@ -2367,8 +2367,8 @@ static void __always_unused i915_pageflip_stall_check(struct drm_device *dev, in
 	} else {
 		int dspaddr = DSPADDR(intel_crtc->plane);
 		stall_detected = I915_READ(dspaddr) == (i915_gem_obj_ggtt_offset(obj) +
-							crtc->y * crtc->fb->pitches[0] +
-							crtc->x * crtc->fb->bits_per_pixel/8);
+							crtc->y * crtc->primary->fb->pitches[0] +
+							crtc->x * crtc->primary->fb->bits_per_pixel/8);
 	spin_unlock_irqrestore(&dev->event_lock, flags);
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index ea66dc2..3ffe5a6 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -744,7 +744,7 @@ bool intel_crtc_active(struct drm_crtc *crtc)
 	 * We can ditch the crtc->fb check as soon as we can
 	 * properly reconstruct framebuffers.
-	return intel_crtc->active && crtc->fb &&
+	return intel_crtc->active && crtc->primary->fb &&
 		intel_crtc->config.adjusted_mode.crtc_clock;
@@ -2291,8 +2291,8 @@ void intel_display_handle_reset(struct drm_device *dev)
 		 * disabling them without disabling the entire crtc) allow again
 		 * a NULL crtc->fb.
-		if (intel_crtc->active && crtc->fb)
-			dev_priv->display.update_plane(crtc, crtc->fb,
+		if (intel_crtc->active && crtc->primary->fb)
+			dev_priv->display.update_plane(crtc, crtc->primary->fb,
 						       crtc->x, crtc->y);
 		mutex_unlock(&crtc->mutex);
@@ -2417,8 +2417,8 @@ intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
 		return ret;
-	crtc->fb = fb;
 	crtc->x = x;
 	crtc->y = y;
@@ -3009,7 +3009,7 @@ static void intel_crtc_wait_for_pending_flips(struct drm_crtc *crtc)
 	struct drm_i915_private *dev_priv = dev->dev_private;
 		return;
 	WARN_ON(waitqueue_active(&dev_priv->pending_flip_queue));
@@ -3018,7 +3018,7 @@ static void intel_crtc_wait_for_pending_flips(struct drm_crtc *crtc)
 		   !intel_crtc_has_pending_flip(crtc));
 	mutex_lock(&dev->struct_mutex);
-	intel_finish_fb(crtc->fb);
+	intel_finish_fb(crtc->primary->fb);
 	mutex_unlock(&dev->struct_mutex);
@@ -4466,11 +4466,11 @@ static void intel_crtc_disable(struct drm_crtc *crtc)
 	assert_cursor_disabled(dev_priv, to_intel_crtc(crtc)->pipe);
 	assert_pipe_disabled(dev->dev_private, to_intel_crtc(crtc)->pipe);
-	if (crtc->fb) {
-		intel_unpin_fb_obj(to_intel_framebuffer(crtc->fb)->obj);
+		intel_unpin_fb_obj(to_intel_framebuffer(crtc->primary->fb)->obj);
-		crtc->fb = NULL;
 	/* Update computed state. */
@@ -8249,7 +8249,7 @@ void intel_mark_idle(struct drm_device *dev)
 		goto out;
-		if (!crtc->fb)
 			continue;
 		intel_decrease_pllclock(crtc);
@@ -8272,10 +8272,10 @@ void intel_mark_fb_busy(struct drm_i915_gem_object *obj,
 		return;
-		if (!crtc->fb)
 			continue;
-		if (to_intel_framebuffer(crtc->fb)->obj != obj)
+		if (to_intel_framebuffer(crtc->primary->fb)->obj != obj)
 			continue;
 		intel_increase_pllclock(crtc);
@@ -8703,7 +8703,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	struct drm_i915_gem_object *obj = to_intel_framebuffer(fb)->obj;
 	struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
 	struct intel_unpin_work *work;
@@ -8711,7 +8711,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	int ret;
 	/* Can't change pixel format via MI display flips. */
 		return -EINVAL;
@@ -8719,8 +8719,8 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	 * Note that pitch changes could also affect these register.
 	if (INTEL_INFO(dev)->gen > 3 &&
-	    (fb->offsets[0] != crtc->fb->offsets[0] ||
-	     fb->pitches[0] != crtc->fb->pitches[0]))
+	    (fb->offsets[0] != crtc->primary->fb->offsets[0] ||
+	     fb->pitches[0] != crtc->primary->fb->pitches[0]))
 		return -EINVAL;
 	if (i915_terminally_wedged(&dev_priv->gpu_error))
@@ -8763,7 +8763,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	drm_gem_object_reference(&work->old_fb_obj->base);
 	drm_gem_object_reference(&obj->base);
-	crtc->fb = fb;
 	work->pending_flip_obj = obj;
@@ -8786,7 +8786,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 cleanup_pending:
 	atomic_dec(&intel_crtc->unpin_work_count);
 	drm_gem_object_unreference(&work->old_fb_obj->base);
 	drm_gem_object_unreference(&obj->base);
@@ -9803,7 +9803,7 @@ static int intel_set_mode(struct drm_crtc *crtc,
 void intel_crtc_restore_mode(struct drm_crtc *crtc)
-	intel_set_mode(crtc, &crtc->mode, crtc->x, crtc->y, crtc->fb);
+	intel_set_mode(crtc, &crtc->mode, crtc->x, crtc->y, crtc->primary->fb);
 #undef for_each_intel_crtc_masked
@@ -9927,9 +9927,9 @@ intel_set_config_compute_mode_changes(struct drm_mode_set *set,
 	if (is_crtc_connector_off(set)) {
 		config->mode_changed = true;
-	} else if (set->crtc->fb != set->fb) {
+	} else if (set->crtc->primary->fb != set->fb) {
 				to_intel_crtc(set->crtc);
@@ -9943,7 +9943,7 @@ intel_set_config_compute_mode_changes(struct drm_mode_set *set,
 		} else {
 			config->fb_changed = true;
@@ -10156,7 +10156,7 @@ static int intel_crtc_set_config(struct drm_mode_set *set)
 	/* Compute whether we need a full modeset, only an fb base update or no
 	 * change at all. In the future we might also check whether only the
@@ -11473,7 +11473,7 @@ void intel_modeset_setup_hw_state(struct drm_device *dev,
 			__intel_set_mode(crtc, &crtc->mode, crtc->x, crtc->y,
-					 crtc->fb);
 	} else {
 		intel_modeset_update_staged_output_state(dev);
@@ -11522,7 +11522,7 @@ void intel_modeset_cleanup(struct drm_device *dev)
 		/* Skip inactive CRTCs */
-		if (!crtc->fb)
 			continue;
diff --git a/drivers/gpu/drm/i915/intel_dp.c b/drivers/gpu/drm/i915/intel_dp.c
index f2833de..f2fedc0 100644
--- a/drivers/gpu/drm/i915/intel_dp.c
+++ b/drivers/gpu/drm/i915/intel_dp.c
@@ -1744,7 +1744,7 @@ static bool intel_edp_psr_match_conditions(struct intel_dp *intel_dp)
 	struct drm_crtc *crtc = dig_port->base.base.crtc;
-	struct drm_i915_gem_object *obj = to_intel_framebuffer(crtc->fb)->obj;
+	struct drm_i915_gem_object *obj = to_intel_framebuffer(crtc->primary->fb)->obj;
 	struct intel_encoder *intel_encoder = &dp_to_dig_port(intel_dp)->base;
 	dev_priv->psr.source_ok = false;
@@ -1777,7 +1777,7 @@ static bool intel_edp_psr_match_conditions(struct intel_dp *intel_dp)
 		return false;
-	obj = to_intel_framebuffer(crtc->fb)->obj;
+	obj = to_intel_framebuffer(crtc->primary->fb)->obj;
 	if (obj->tiling_mode != I915_TILING_X ||
 	    obj->fence_reg == I915_FENCE_REG_NONE) {
 		DRM_DEBUG_KMS("PSR condition failed: fb not tiled or fenced\n");
diff --git a/drivers/gpu/drm/i915/intel_overlay.c b/drivers/gpu/drm/i915/intel_overlay.c
index 312961a..623cd32 100644
--- a/drivers/gpu/drm/i915/intel_overlay.c
+++ b/drivers/gpu/drm/i915/intel_overlay.c
@@ -606,14 +606,14 @@ static void update_colorkey(struct intel_overlay *overlay,
 	u32 key = overlay->color_key;
-	switch (overlay->crtc->base.fb->bits_per_pixel) {
+	switch (overlay->crtc->base.primary->fb->bits_per_pixel) {
 	case 8:
 		iowrite32(0, &regs->DCLRKV);
 		iowrite32(CLK_RGB8I_MASK | DST_KEY_ENABLE, &regs->DCLRKM);
 		break;
 	case 16:
-		if (overlay->crtc->base.fb->depth == 15) {
+		if (overlay->crtc->base.primary->fb->depth == 15) {
 			iowrite32(RGB15_TO_COLORKEY(key), &regs->DCLRKV);
 			iowrite32(CLK_RGB15_MASK | DST_KEY_ENABLE,
 				  &regs->DCLRKM);
diff --git a/drivers/gpu/drm/i915/intel_pm.c b/drivers/gpu/drm/i915/intel_pm.c
index 66f9565..f070d5d 100644
--- a/drivers/gpu/drm/i915/intel_pm.c
+++ b/drivers/gpu/drm/i915/intel_pm.c
@@ -92,7 +92,7 @@ static void i8xx_enable_fbc(struct drm_crtc *crtc)
-	struct drm_framebuffer *fb = crtc->fb;
+	struct drm_framebuffer *fb = crtc->primary->fb;
 	struct intel_framebuffer *intel_fb = to_intel_framebuffer(fb);
 	struct drm_i915_gem_object *obj = intel_fb->obj;
@@ -149,7 +149,7 @@ static void g4x_enable_fbc(struct drm_crtc *crtc)
@@ -221,7 +221,7 @@ static void ironlake_enable_fbc(struct drm_crtc *crtc)
@@ -277,7 +277,7 @@ static void gen7_enable_fbc(struct drm_crtc *crtc)
@@ -336,11 +336,11 @@ static void intel_fbc_work_fn(struct work_struct *__work)
 		/* Double check that we haven't switched fb without cancelling
 		 * the prior work.
-		if (work->crtc->fb == work->fb) {
+		if (work->crtc->primary->fb == work->fb) {
 			dev_priv->display.enable_fbc(work->crtc);
 			dev_priv->fbc.plane = to_intel_crtc(work->crtc)->plane;
-			dev_priv->fbc.fb_id = work->crtc->fb->base.id;
+			dev_priv->fbc.fb_id = work->crtc->primary->fb->base.id;
 			dev_priv->fbc.y = work->crtc->y;
@@ -393,7 +393,7 @@ static void intel_enable_fbc(struct drm_crtc *crtc)
 	work->crtc = crtc;
-	work->fb = crtc->fb;
+	work->fb = crtc->primary->fb;
 	INIT_DELAYED_WORK(&work->work, intel_fbc_work_fn);
 	dev_priv->fbc.fbc_work = work;
@@ -499,14 +499,14 @@ void intel_update_fbc(struct drm_device *dev)
-	if (!crtc || crtc->fb == NULL) {
+	if (!crtc || crtc->primary->fb == NULL) {
 		if (set_no_fbc_reason(dev_priv, FBC_NO_OUTPUT))
 			DRM_DEBUG_KMS("no output, disabling\n");
 		goto out_disable;
-	fb = crtc->fb;
 	adjusted_mode = &intel_crtc->config.adjusted_mode;
@@ -1041,7 +1041,7 @@ static void pineview_update_wm(struct drm_crtc *unused_crtc)
 	crtc = single_enabled_crtc(dev);
 	if (crtc) {
 		const struct drm_display_mode *adjusted_mode;
-		int pixel_size = crtc->fb->bits_per_pixel / 8;
+		int pixel_size = crtc->primary->fb->bits_per_pixel / 8;
 		int clock;
 		adjusted_mode = &to_intel_crtc(crtc)->config.adjusted_mode;
@@ -1121,7 +1121,7 @@ static bool g4x_compute_wm0(struct drm_device *dev,
 	clock = adjusted_mode->crtc_clock;
 	htotal = adjusted_mode->crtc_htotal;
 	hdisplay = to_intel_crtc(crtc)->config.pipe_src_w;
-	pixel_size = crtc->fb->bits_per_pixel / 8;
+	pixel_size = crtc->primary->fb->bits_per_pixel / 8;
 	/* Use the small buffer method to calculate plane watermark */
 	entries = ((clock * pixel_size / 1000) * display_latency_ns) / 1000;
@@ -1208,7 +1208,7 @@ static bool g4x_compute_srwm(struct drm_device *dev,
 	line_time_us = max(htotal * 1000 / clock, 1);
 	line_count = (latency_ns / line_time_us + 1000) / 1000;
@@ -1247,7 +1247,7 @@ static bool vlv_compute_drain_latency(struct drm_device *dev,
 		return false;
 	clock = to_intel_crtc(crtc)->config.adjusted_mode.crtc_clock;
-	pixel_size = crtc->fb->bits_per_pixel / 8;	/* BPP */
+	pixel_size = crtc->primary->fb->bits_per_pixel / 8;	/* BPP */
 	entries = (clock / 1000) * pixel_size;
 	*plane_prec_mult = (entries > 256) ?
@@ -1439,7 +1439,7 @@ static void i965_update_wm(struct drm_crtc *unused_crtc)
 		int clock = adjusted_mode->crtc_clock;
 		int htotal = adjusted_mode->crtc_htotal;
 		int hdisplay = to_intel_crtc(crtc)->config.pipe_src_w;
 		unsigned long line_time_us;
 		int entries;
@@ -1512,7 +1512,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
 	crtc = intel_get_crtc_for_plane(dev, 0);
 	if (intel_crtc_active(crtc)) {
-		int cpp = crtc->fb->bits_per_pixel / 8;
+		int cpp = crtc->primary->fb->bits_per_pixel / 8;
 		if (IS_GEN2(dev))
 			cpp = 4;
@@ -1528,7 +1528,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
 	crtc = intel_get_crtc_for_plane(dev, 1);
 		if (IS_GEN2(dev))
 			cpp = 4;
@@ -1565,7 +1565,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
 		int hdisplay = to_intel_crtc(enabled)->config.pipe_src_w;
-		int pixel_size = enabled->fb->bits_per_pixel / 8;
+		int pixel_size = enabled->primary->fb->bits_per_pixel / 8;
 		int entries;
@@ -2117,7 +2117,7 @@ static void ilk_compute_wm_parameters(struct drm_crtc *crtc,
 	if (p->active) {
 		p->pipe_htotal = intel_crtc->config.adjusted_mode.crtc_htotal;
 		p->pixel_rate = ilk_pipe_pixel_rate(dev, crtc);
-		p->pri.bytes_per_pixel = crtc->fb->bits_per_pixel / 8;
+		p->pri.bytes_per_pixel = crtc->primary->fb->bits_per_pixel / 8;
 		p->cur.bytes_per_pixel = 4;
 		p->pri.horiz_pixels = intel_crtc->config.pipe_src_w;
 		p->cur.horiz_pixels = 64;
diff --git a/drivers/gpu/drm/mgag200/mgag200_mode.c b/drivers/gpu/drm/mgag200/mgag200_mode.c
index 9683747..a034ed4 100644
--- a/drivers/gpu/drm/mgag200/mgag200_mode.c
+++ b/drivers/gpu/drm/mgag200/mgag200_mode.c
@@ -29,7 +29,7 @@ static void mga_crtc_load_lut(struct drm_crtc *crtc)
 	struct mga_crtc *mga_crtc = to_mga_crtc(crtc);
 	struct mga_device *mdev = dev->dev_private;
 	int i;
 	if (!crtc->enabled)
@@ -742,7 +742,7 @@ static int mga_crtc_do_set_base(struct drm_crtc *crtc,
 		mgag200_bo_unreserve(bo);
-	mga_fb = to_mga_framebuffer(crtc->fb);
+	mga_fb = to_mga_framebuffer(crtc->primary->fb);
 	obj = mga_fb->obj;
 	bo = gem_to_mga_bo(obj);
@@ -805,7 +805,7 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
 		/* 0x48: */        0,    0,    0,    0,    0,    0,    0,    0
-	bppshift = mdev->bpp_shifts[(crtc->fb->bits_per_pixel >> 3) - 1];
+	bppshift = mdev->bpp_shifts[(crtc->primary->fb->bits_per_pixel >> 3) - 1];
 	switch (mdev->type) {
 	case G200_SE_A:
@@ -843,12 +843,12 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
 		break;
 	case 8:
 		dacvalue[MGA1064_MUL_CTL] = MGA1064_MUL_CTL_8bits;
 		break;
 	case 16:
 			dacvalue[MGA1064_MUL_CTL] = MGA1064_MUL_CTL_15bits;
 		else
 			dacvalue[MGA1064_MUL_CTL] = MGA1064_MUL_CTL_16bits;
@@ -896,8 +896,8 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
 	WREG_SEQ(3, 0);
 	WREG_SEQ(4, 0xe);
-	pitch = crtc->fb->pitches[0] / (crtc->fb->bits_per_pixel / 8);
-	if (crtc->fb->bits_per_pixel == 24)
+	pitch = crtc->primary->fb->pitches[0] / (crtc->primary->fb->bits_per_pixel / 8);
+	if (crtc->primary->fb->bits_per_pixel == 24)
 		pitch = (pitch * 3) >> (4 - bppshift);
 	else
 		pitch = pitch >> (4 - bppshift);
@@ -974,7 +974,7 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
 		((vdisplay & 0xc00) >> 7) |
 		((vsyncstart & 0xc00) >> 5) |
 		((vdisplay & 0x400) >> 3);
 		ext_vga[3] = (((1 << bppshift) * 3) - 1) | 0x80;
 	else
 		ext_vga[3] = ((1 << bppshift) - 1) | 0x80;
@@ -1034,9 +1034,9 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
 			u32 bpp;
 			u32 mb;
-			if (crtc->fb->bits_per_pixel > 16)
+			if (crtc->primary->fb->bits_per_pixel > 16)
 				bpp = 32;
-			else if (crtc->fb->bits_per_pixel > 8)
+			else if (crtc->primary->fb->bits_per_pixel > 8)
 				bpp = 16;
 			else
 				bpp = 8;
@@ -1277,8 +1277,8 @@ static void mga_crtc_disable(struct drm_crtc *crtc)
 	int ret;
 	DRM_DEBUG_KMS("\n");
 	mga_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
-	if (crtc->fb) {
-		struct mga_framebuffer *mga_fb = to_mga_framebuffer(crtc->fb);
+		struct mga_framebuffer *mga_fb = to_mga_framebuffer(crtc->primary->fb);
 		struct drm_gem_object *obj = mga_fb->obj;
 		struct mgag200_bo *bo = gem_to_mga_bo(obj);
 		ret = mgag200_bo_reserve(bo, false);
@@ -1287,7 +1287,7 @@ static void mga_crtc_disable(struct drm_crtc *crtc)
 		mgag200_bo_push_sysram(bo);
-	crtc->fb = NULL;
 /* These provide the minimum set of functions required to handle a CRTC */
diff --git a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
index fc1cdfa..3e6c0f3 100644
--- a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
+++ b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
@@ -120,7 +120,7 @@ static void update_fb(struct drm_crtc *crtc, struct drm_framebuffer *new_fb)
 	/* grab reference to incoming scanout fb: */
 	drm_framebuffer_reference(new_fb);
-	mdp4_crtc->base.fb = new_fb;
+	mdp4_crtc->base.primary->fb = new_fb;
 	mdp4_crtc->fb = new_fb;
 	if (old_fb)
@@ -182,7 +182,7 @@ static void pageflip_cb(struct msm_fence_cb *cb)
 	struct mdp4_crtc *mdp4_crtc =
 		container_of(cb, struct mdp4_crtc, pageflip_cb);
 	struct drm_crtc *crtc = &mdp4_crtc->base;
 	if (!fb)
 		return;
@@ -348,14 +348,14 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
 			mode->type, mode->flags);
 	/* grab extra ref for update_scanout() */
-	ret = mdp4_plane_mode_set(mdp4_crtc->plane, crtc, crtc->fb,
+	ret = mdp4_plane_mode_set(mdp4_crtc->plane, crtc, crtc->primary->fb,
 			0, 0, mode->hdisplay, mode->vdisplay,
 			x << 16, y << 16,
 			mode->hdisplay << 16, mode->vdisplay << 16);
 	if (ret) {
-		drm_framebuffer_unreference(crtc->fb);
+		drm_framebuffer_unreference(crtc->primary->fb);
 		dev_err(crtc->dev->dev, "%s: failed to set mode on plane: %d\n",
 				mdp4_crtc->name, ret);
 		return ret;
@@ -368,7 +368,7 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
 	/* take data from pipe: */
 	mdp4_write(mdp4_kms, REG_MDP4_DMA_SRC_BASE(dma), 0);
 	mdp4_write(mdp4_kms, REG_MDP4_DMA_SRC_STRIDE(dma),
-			crtc->fb->pitches[0]);
+			crtc->primary->fb->pitches[0]);
 	mdp4_write(mdp4_kms, REG_MDP4_DMA_DST_SIZE(dma),
 			MDP4_DMA_DST_SIZE_WIDTH(0) |
 			MDP4_DMA_DST_SIZE_HEIGHT(0));
@@ -378,7 +378,7 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
 			MDP4_OVLP_SIZE_WIDTH(mode->hdisplay) |
 			MDP4_OVLP_SIZE_HEIGHT(mode->vdisplay));
 	mdp4_write(mdp4_kms, REG_MDP4_OVLP_STRIDE(ovlp),
 	mdp4_write(mdp4_kms, REG_MDP4_OVLP_CFG(ovlp), 1);
@@ -388,8 +388,8 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
 		mdp4_write(mdp4_kms, REG_MDP4_DMA_E_QUANT(2), 0x00ff0000);
-	update_fb(crtc, crtc->fb);
-	update_scanout(crtc, crtc->fb);
+	update_fb(crtc, crtc->primary->fb);
+	update_scanout(crtc, crtc->primary->fb);
 	return 0;
@@ -420,19 +420,19 @@ static int mdp4_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 	int ret;
-	ret = mdp4_plane_mode_set(plane, crtc, crtc->fb,
+	ret = mdp4_plane_mode_set(plane, crtc, crtc->primary->fb,
 			x << 16, y << 16,
 	if (ret) {
 		return ret;
 	return 0;
diff --git a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
index 54afdb2..6ea10bd 100644
--- a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
+++ b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
@@ -102,7 +102,7 @@ static void update_fb(struct drm_crtc *crtc, struct drm_framebuffer *new_fb)
-	mdp5_crtc->base.fb = new_fb;
+	mdp5_crtc->base.primary->fb = new_fb;
 	mdp5_crtc->fb = new_fb;
 	if (old_fb)
@@ -289,14 +289,14 @@ static int mdp5_crtc_mode_set(struct drm_crtc *crtc,
-	ret = mdp5_plane_mode_set(mdp5_crtc->plane, crtc, crtc->fb,
+	ret = mdp5_plane_mode_set(mdp5_crtc->plane, crtc, crtc->primary->fb,
 			x << 16, y << 16,
 	if (ret) {
 				mdp5_crtc->name, ret);
 		return ret;
@@ -306,8 +306,8 @@ static int mdp5_crtc_mode_set(struct drm_crtc *crtc,
 			MDP5_LM_OUT_SIZE_WIDTH(mode->hdisplay) |
 			MDP5_LM_OUT_SIZE_HEIGHT(mode->vdisplay));
 	return 0;
@@ -338,19 +338,19 @@ static int mdp5_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 	int ret;
-	ret = mdp5_plane_mode_set(plane, crtc, crtc->fb,
+	ret = mdp5_plane_mode_set(plane, crtc, crtc->primary->fb,
 			x << 16, y << 16,
 	if (ret) {
 		return ret;
 	return 0;
diff --git a/drivers/gpu/drm/nouveau/dispnv04/crtc.c b/drivers/gpu/drm/nouveau/dispnv04/crtc.c
index 1caef1f..41be342 100644
--- a/drivers/gpu/drm/nouveau/dispnv04/crtc.c
+++ b/drivers/gpu/drm/nouveau/dispnv04/crtc.c
@@ -239,7 +239,7 @@ nv_crtc_mode_set_vga(struct drm_crtc *crtc, struct drm_display_mode *mode)
 	struct nouveau_crtc *nv_crtc = nouveau_crtc(crtc);
 	struct nv04_crtc_reg *regp = &nv04_display(dev)->mode_reg.crtc_reg[nv_crtc->index];
 	/* Calculate our timings */
 	int horizDisplay	= (mode->crtc_hdisplay >> 3)		- 1;
@@ -574,7 +574,7 @@ nv_crtc_mode_set_regs(struct drm_crtc *crtc, struct drm_display_mode * mode)
 		regp->CRTC[NV_CIO_CRE_86] = 0x1;
-	regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] = (crtc->fb->depth + 1) / 8;
+	regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] = (crtc->primary->fb->depth + 1) / 8;
 	/* Enable slaved mode (called MODE_TV in nv4ref.h) */
 	if (lvds_output || tmds_output || tv_output)
 		regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] |= (1 << 7);
@@ -588,7 +588,7 @@ nv_crtc_mode_set_regs(struct drm_crtc *crtc, struct drm_display_mode * mode)
 	regp->ramdac_gen_ctrl = NV_PRAMDAC_GENERAL_CONTROL_BPC_8BITS |
 				NV_PRAMDAC_GENERAL_CONTROL_VGA_STATE_SEL |
 				NV_PRAMDAC_GENERAL_CONTROL_PIXMIX_ON;
-	if (crtc->fb->depth == 16)
+	if (crtc->primary->fb->depth == 16)
 		regp->ramdac_gen_ctrl |= NV_PRAMDAC_GENERAL_CONTROL_ALT_MODE_SEL;
 	if (nv_device(drm->device)->chipset >= 0x11)
 		regp->ramdac_gen_ctrl |= NV_PRAMDAC_GENERAL_CONTROL_PIPE_LONG;
@@ -609,7 +609,7 @@ static int
 nv_crtc_swap_fbs(struct drm_crtc *crtc, struct drm_framebuffer *old_fb)
 	struct nv04_display *disp = nv04_display(crtc->dev);
-	struct nouveau_framebuffer *nvfb = nouveau_framebuffer(crtc->fb);
+	struct nouveau_framebuffer *nvfb = nouveau_framebuffer(crtc->primary->fb);
 	int ret;
@@ -808,7 +808,7 @@ nv_crtc_gamma_set(struct drm_crtc *crtc, u16 *r, u16 *g, u16 *b, uint32_t start,
 	 * mark the lut values as dirty by setting depth==0, and it'll be
 	 * uploaded on the first mode_set_base()
-	if (!nv_crtc->base.fb) {
+	if (!nv_crtc->base.primary->fb) {
 		nv_crtc->lut.depth = 0;
 		return;
@@ -832,7 +832,7 @@ nv04_crtc_do_mode_set_base(struct drm_crtc *crtc,
 	NV_DEBUG(drm, "index %d\n", nv_crtc->index);
 	/* no fb bound */
-	if (!atomic && !crtc->fb) {
+	if (!atomic && !crtc->primary->fb) {
 		NV_DEBUG(drm, "No FB bound\n");
 		return 0;
@@ -844,8 +844,8 @@ nv04_crtc_do_mode_set_base(struct drm_crtc *crtc,
 		drm_fb = passed_fb;
 		fb = nouveau_framebuffer(passed_fb);
 	} else {
-		drm_fb = crtc->fb;
-		fb = nouveau_framebuffer(crtc->fb);
+		drm_fb = crtc->primary->fb;
+		fb = nouveau_framebuffer(crtc->primary->fb);
 	nv_crtc->fb.offset = fb->nvbo->bo.offset;
@@ -857,9 +857,9 @@ nv04_crtc_do_mode_set_base(struct drm_crtc *crtc,
 	/* Update the framebuffer format. */
 	regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] &= ~3;
-	regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] |= (crtc->fb->depth + 1) / 8;
+	regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] |= (crtc->primary->fb->depth + 1) / 8;
 	regp->ramdac_gen_ctrl &= ~NV_PRAMDAC_GENERAL_CONTROL_ALT_MODE_SEL;
 	crtc_wr_cio_state(crtc, regp, NV_CIO_CRE_PIXEL_INDEX);
 	NVWriteRAMDAC(dev, nv_crtc->index, NV_PRAMDAC_GENERAL_CONTROL,
diff --git a/drivers/gpu/drm/nouveau/dispnv04/dfp.c b/drivers/gpu/drm/nouveau/dispnv04/dfp.c
index 7fdc51e..a2d669b 100644
--- a/drivers/gpu/drm/nouveau/dispnv04/dfp.c
+++ b/drivers/gpu/drm/nouveau/dispnv04/dfp.c
@@ -415,7 +415,7 @@ static void nv04_dfp_mode_set(struct drm_encoder *encoder,
 	/* Output property. */
 	if ((nv_connector->dithering_mode == DITHERING_MODE_ON) ||
 	    (nv_connector->dithering_mode == DITHERING_MODE_AUTO &&
-	     encoder->crtc->fb->depth > connector->display_info.bpc * 3)) {
+	     encoder->crtc->primary->fb->depth > connector->display_info.bpc * 3)) {
 		if (nv_device(drm->device)->chipset == 0x11)
 			regp->dither = savep->dither | 0x00010000;
 		else {
diff --git a/drivers/gpu/drm/nouveau/nouveau_display.c b/drivers/gpu/drm/nouveau/nouveau_display.c
index b1547b0..3ff030d 100644
--- a/drivers/gpu/drm/nouveau/nouveau_display.c
+++ b/drivers/gpu/drm/nouveau/nouveau_display.c
@@ -571,7 +571,7 @@ nouveau_display_suspend(struct drm_device *dev)
 		struct nouveau_framebuffer *nouveau_fb;
-		nouveau_fb = nouveau_framebuffer(crtc->fb);
+		nouveau_fb = nouveau_framebuffer(crtc->primary->fb);
 		if (!nouveau_fb || !nouveau_fb->nvbo)
 			continue;
@@ -598,7 +598,7 @@ nouveau_display_repin(struct drm_device *dev)
 			continue;
@@ -695,7 +695,7 @@ nouveau_crtc_page_flip(struct drm_crtc *crtc, struct drm_framebuffer *fb,
 	const int swap_interval = (flags & DRM_MODE_PAGE_FLIP_ASYNC) ? 0 : 1;
 	struct nouveau_drm *drm = nouveau_drm(dev);
-	struct nouveau_bo *old_bo = nouveau_framebuffer(crtc->fb)->nvbo;
+	struct nouveau_bo *old_bo = nouveau_framebuffer(crtc->primary->fb)->nvbo;
 	struct nouveau_bo *new_bo = nouveau_framebuffer(fb)->nvbo;
 	struct nouveau_page_flip_state *s;
 	struct nouveau_channel *chan = drm->channel;
@@ -769,7 +769,7 @@ nouveau_crtc_page_flip(struct drm_crtc *crtc, struct drm_framebuffer *fb,
 		goto fail_unreserve;
 	/* Update the crtc struct and cleanup */
-	crtc->fb = fb;
 	nouveau_bo_fence(old_bo, fence);
 	ttm_bo_unreserve(&old_bo->bo);
diff --git a/drivers/gpu/drm/nouveau/nv50_display.c b/drivers/gpu/drm/nouveau/nv50_display.c
index 2dccafc..58af547 100644
--- a/drivers/gpu/drm/nouveau/nv50_display.c
+++ b/drivers/gpu/drm/nouveau/nv50_display.c
@@ -651,7 +651,7 @@ nv50_crtc_set_dither(struct nouveau_crtc *nv_crtc, bool update)
 	nv_connector = nouveau_crtc_connector_get(nv_crtc);
 	connector = &nv_connector->base;
 	if (nv_connector->dithering_mode == DITHERING_MODE_AUTO) {
-		if (nv_crtc->base.fb->depth > connector->display_info.bpc * 3)
+		if (nv_crtc->base.primary->fb->depth > connector->display_info.bpc * 3)
 			mode = DITHERING_MODE_DYNAMIC2X2;
 	} else {
 		mode = nv_connector->dithering_mode;
@@ -785,7 +785,8 @@ nv50_crtc_set_scale(struct nouveau_crtc *nv_crtc, bool update)
 		if (update) {
 			nv50_display_flip_stop(crtc);
-			nv50_display_flip_next(crtc, crtc->fb, NULL, 1);
+			nv50_display_flip_next(crtc, crtc->primary->fb,
+					       NULL, 1);
@@ -1028,7 +1029,7 @@ nv50_crtc_commit(struct drm_crtc *crtc)
 	nv50_crtc_cursor_show_hide(nv_crtc, nv_crtc->cursor.visible, true);
+	nv50_display_flip_next(crtc, crtc->primary->fb, NULL, 1);
 static bool
@@ -1042,7 +1043,7 @@ nv50_crtc_mode_fixup(struct drm_crtc *crtc, const struct drm_display_mode *mode,
 static int
 nv50_crtc_swap_fbs(struct drm_crtc *crtc, struct drm_framebuffer *old_fb)
 	struct nv50_head *head = nv50_head(crtc);
 	int ret;
@@ -1139,7 +1140,7 @@ nv50_crtc_mode_set(struct drm_crtc *crtc, struct drm_display_mode *umode,
 	nv50_crtc_set_dither(nv_crtc, false);
 	nv50_crtc_set_scale(nv_crtc, false);
 	nv50_crtc_set_color_vibrance(nv_crtc, false);
-	nv50_crtc_set_image(nv_crtc, crtc->fb, x, y, false);
+	nv50_crtc_set_image(nv_crtc, crtc->primary->fb, x, y, false);
 	return 0;
@@ -1151,7 +1152,7 @@ nv50_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 	int ret;
-	if (!crtc->fb) {
 		return 0;
@@ -1161,8 +1162,8 @@ nv50_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 		return ret;
-	nv50_crtc_set_image(nv_crtc, crtc->fb, x, y, true);
+	nv50_crtc_set_image(nv_crtc, crtc->primary->fb, x, y, true);
 	return 0;
diff --git a/drivers/gpu/drm/omapdrm/omap_crtc.c b/drivers/gpu/drm/omapdrm/omap_crtc.c
index 4313bb0..355157e 100644
--- a/drivers/gpu/drm/omapdrm/omap_crtc.c
+++ b/drivers/gpu/drm/omapdrm/omap_crtc.c
@@ -245,7 +245,7 @@ static int omap_crtc_mode_set(struct drm_crtc *crtc,
 	copy_timings_drm_to_omap(&omap_crtc->timings, mode);
 	omap_crtc->full_update = true;
-	return omap_plane_mode_set(omap_crtc->plane, crtc, crtc->fb,
+	return omap_plane_mode_set(omap_crtc->plane, crtc, crtc->primary->fb,
 			x << 16, y << 16,
 			mode->hdisplay << 16, mode->vdisplay << 16,
@@ -273,7 +273,7 @@ static int omap_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
 	struct drm_plane *plane = omap_crtc->plane;
 	struct drm_display_mode *mode = &crtc->mode;
-	return omap_plane_mode_set(plane, crtc, crtc->fb,
+	return omap_plane_mode_set(plane, crtc, crtc->primary->fb,
 			x << 16, y << 16,
@@ -308,14 +308,14 @@ static void page_flip_worker(struct work_struct *work)
 	struct drm_gem_object *bo;
-	omap_plane_mode_set(omap_crtc->plane, crtc, crtc->fb,
+	omap_plane_mode_set(omap_crtc->plane, crtc, crtc->primary->fb,
 			crtc->x << 16, crtc->y << 16,
 			vblank_cb, crtc);
-	bo = omap_framebuffer_bo(crtc->fb, 0);
+	bo = omap_framebuffer_bo(crtc->primary->fb, 0);
 	drm_gem_object_unreference_unlocked(bo);
@@ -336,9 +336,10 @@ static int omap_crtc_page_flip_locked(struct drm_crtc *crtc,
 	struct omap_crtc *omap_crtc = to_omap_crtc(crtc);
+	struct drm_plane *primary = crtc->primary;
-	DBG("%d -> %d (event=%p)", crtc->fb ? crtc->fb->base.id : -1,
+	DBG("%d -> %d (event=%p)", primary->fb ? primary->fb->base.id : -1,
 			fb->base.id, event);
 	if (omap_crtc->old_fb) {
@@ -347,7 +348,7 @@ static int omap_crtc_page_flip_locked(struct drm_crtc *crtc,
 	omap_crtc->event = event;
-	crtc->fb = fb;
+	primary->fb = fb;
 	 * Hold a reference temporarily until the crtc is updated
diff --git a/drivers/gpu/drm/omapdrm/omap_fb.c b/drivers/gpu/drm/omapdrm/omap_fb.c
index f466c4a..0d5e9b7 100644
--- a/drivers/gpu/drm/omapdrm/omap_fb.c
+++ b/drivers/gpu/drm/omapdrm/omap_fb.c
@@ -312,7 +312,7 @@ struct drm_connector *omap_framebuffer_get_next_connector(
 		if (connector != from) {
 			struct drm_encoder *encoder = connector->encoder;
 			struct drm_crtc *crtc = encoder ? encoder->crtc : NULL;
-			if (crtc && crtc->fb == fb)
+			if (crtc && crtc->primary->fb == fb)
 				return connector;
diff --git a/drivers/gpu/drm/qxl/qxl_display.c b/drivers/gpu/drm/qxl/qxl_display.c
index 798bde2..41bdd17 100644
--- a/drivers/gpu/drm/qxl/qxl_display.c
+++ b/drivers/gpu/drm/qxl/qxl_display.c
@@ -527,7 +527,7 @@ static int qxl_crtc_mode_set(struct drm_crtc *crtc,
 	bool recreate_primary = false;
 	int ret;
 	int surf_id;
-	if (!crtc->fb) {
 		DRM_DEBUG_KMS("No FB bound\n");
 		return 0;
@@ -536,7 +536,7 @@ static int qxl_crtc_mode_set(struct drm_crtc *crtc,
 		qfb = to_qxl_framebuffer(old_fb);
 		old_bo = gem_to_qxl_bo(qfb->obj);
-	qfb = to_qxl_framebuffer(crtc->fb);
+	qfb = to_qxl_framebuffer(crtc->primary->fb);
 	if (!m)
 		/* and do we care? */
@@ -609,14 +609,14 @@ static void qxl_crtc_disable(struct drm_crtc *crtc)
 	struct qxl_crtc *qcrtc = to_qxl_crtc(crtc);
 	struct qxl_device *qdev = dev->dev_private;
-	if (crtc->fb) {
-		struct qxl_framebuffer *qfb = to_qxl_framebuffer(crtc->fb);
+		struct qxl_framebuffer *qfb = to_qxl_framebuffer(crtc->primary->fb);
 		struct qxl_bo *bo = gem_to_qxl_bo(qfb->obj);
 		int ret;
 		ret = qxl_bo_reserve(bo, false);
 		qxl_bo_unpin(bo);
 		qxl_bo_unreserve(bo);
-		crtc->fb = NULL;
 	qxl_monitors_config_set(qdev, qcrtc->index, 0, 0, 0, 0, 0);
diff --git a/drivers/gpu/drm/radeon/atombios_crtc.c b/drivers/gpu/drm/radeon/atombios_crtc.c
index daa4dd3..fb187c7 100644
--- a/drivers/gpu/drm/radeon/atombios_crtc.c
+++ b/drivers/gpu/drm/radeon/atombios_crtc.c
@@ -1106,7 +1106,7 @@ static int dce4_crtc_do_set_base(struct drm_crtc *crtc,
 	int r;
 	/* no fb bound */
 		return 0;
@@ -1116,8 +1116,8 @@ static int dce4_crtc_do_set_base(struct drm_crtc *crtc,
 		target_fb = fb;
 	else {
-		radeon_fb = to_radeon_framebuffer(crtc->fb);
-		target_fb = crtc->fb;
+		radeon_fb = to_radeon_framebuffer(crtc->primary->fb);
+		target_fb = crtc->primary->fb;
 	/* If atomic, assume fb object is pinned & idle & fenced and
@@ -1316,7 +1316,7 @@ static int dce4_crtc_do_set_base(struct drm_crtc *crtc,
 	/* set pageflip to happen anywhere in vblank interval */
 	WREG32(EVERGREEN_MASTER_UPDATE_MODE + radeon_crtc->crtc_offset, 0);
-	if (!atomic && fb && fb != crtc->fb) {
+	if (!atomic && fb && fb != crtc->primary->fb) {
 		radeon_fb = to_radeon_framebuffer(fb);
 		rbo = gem_to_radeon_bo(radeon_fb->obj);
 		r = radeon_bo_reserve(rbo, false);
@@ -1350,7 +1350,7 @@ static int avivo_crtc_do_set_base(struct drm_crtc *crtc,
 	int r;
 	/* no fb bound */
 		return 0;
@@ -1360,8 +1360,8 @@ static int avivo_crtc_do_set_base(struct drm_crtc *crtc,
 		target_fb = fb;
 	else {
 	obj = radeon_fb->obj;
@@ -1485,7 +1485,7 @@ static int avivo_crtc_do_set_base(struct drm_crtc *crtc,
 	WREG32(AVIVO_D1MODE_MASTER_UPDATE_MODE + radeon_crtc->crtc_offset, 0);
@@ -1972,12 +1972,12 @@ static void atombios_crtc_disable(struct drm_crtc *crtc)
 	int i;
 	atombios_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
-	if (crtc->fb) {
 		int r;
 		struct radeon_framebuffer *radeon_fb;
 		struct radeon_bo *rbo;
 		if (unlikely(r))
diff --git a/drivers/gpu/drm/radeon/r100.c b/drivers/gpu/drm/radeon/r100.c
index 030f8e4..b6c3264 100644
--- a/drivers/gpu/drm/radeon/r100.c
+++ b/drivers/gpu/drm/radeon/r100.c
@@ -3220,12 +3220,12 @@ void r100_bandwidth_update(struct radeon_device *rdev)
 	if (rdev->mode_info.crtcs[0]->base.enabled) {
 		mode1 = &rdev->mode_info.crtcs[0]->base.mode;
-		pixel_bytes1 = rdev->mode_info.crtcs[0]->base.fb->bits_per_pixel / 8;
+		pixel_bytes1 = rdev->mode_info.crtcs[0]->base.primary->fb->bits_per_pixel / 8;
 	if (!(rdev->flags & RADEON_SINGLE_CRTC)) {
 		if (rdev->mode_info.crtcs[1]->base.enabled) {
 			mode2 = &rdev->mode_info.crtcs[1]->base.mode;
-			pixel_bytes2 = rdev->mode_info.crtcs[1]->base.fb->bits_per_pixel / 8;
+			pixel_bytes2 = rdev->mode_info.crtcs[1]->base.primary->fb->bits_per_pixel / 8;
diff --git a/drivers/gpu/drm/radeon/radeon_connectors.c b/drivers/gpu/drm/radeon/radeon_connectors.c
index ec958e86..c566b48 100644
--- a/drivers/gpu/drm/radeon/radeon_connectors.c
+++ b/drivers/gpu/drm/radeon/radeon_connectors.c
@@ -89,7 +89,7 @@ static void radeon_property_change_mode(struct drm_encoder *encoder)
 	if (crtc && crtc->enabled) {
diff --git a/drivers/gpu/drm/radeon/radeon_device.c b/drivers/gpu/drm/radeon/radeon_device.c
index 2e72dcd..15f954c 100644
--- a/drivers/gpu/drm/radeon/radeon_device.c
+++ b/drivers/gpu/drm/radeon/radeon_device.c
@@ -1424,7 +1424,7 @@ int radeon_suspend_kms(struct drm_device *dev, bool suspend, bool fbcon)
 	/* unpin the front buffers */
-		struct radeon_framebuffer *rfb = to_radeon_framebuffer(crtc->fb);
+		struct radeon_framebuffer *rfb = to_radeon_framebuffer(crtc->primary->fb);
 		struct radeon_bo *robj;
 		if (rfb == NULL || rfb->obj == NULL) {
diff --git a/drivers/gpu/drm/radeon/radeon_display.c b/drivers/gpu/drm/radeon/radeon_display.c
index fbd8b93..5701fbb 100644
--- a/drivers/gpu/drm/radeon/radeon_display.c
+++ b/drivers/gpu/drm/radeon/radeon_display.c
@@ -369,7 +369,7 @@ static int radeon_crtc_page_flip(struct drm_crtc *crtc,
 	work->rdev = rdev;
 	work->crtc_id = radeon_crtc->crtc_id;
-	old_radeon_fb = to_radeon_framebuffer(crtc->fb);
+	old_radeon_fb = to_radeon_framebuffer(crtc->primary->fb);
 	new_radeon_fb = to_radeon_framebuffer(fb);
 	/* schedule unpin of the old buffer */
 	obj = old_radeon_fb->obj;
@@ -460,7 +460,7 @@ static int radeon_crtc_page_flip(struct drm_crtc *crtc,
 	/* update crtc fb */
-	crtc->fb = fb;
 	r = drm_vblank_get(dev, radeon_crtc->crtc_id);
 	if (r) {
diff --git a/drivers/gpu/drm/radeon/radeon_legacy_crtc.c b/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
index 0b158f9..cafb1cc 100644
--- a/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
+++ b/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
@@ -385,7 +385,7 @@ int radeon_crtc_do_set_base(struct drm_crtc *crtc,
 	/* no fb bound */
 		return 0;
@@ -395,8 +395,8 @@ int radeon_crtc_do_set_base(struct drm_crtc *crtc,
 		target_fb = fb;
 	else {
 	switch (target_fb->bits_per_pixel) {
@@ -444,7 +444,7 @@ retry:
 		 * We don't shutdown the display controller because new buffer
 		 * will end up in same spot.
 			struct radeon_bo *old_rbo;
 			unsigned long nsize, osize;
@@ -555,7 +555,7 @@ retry:
 	WREG32(RADEON_CRTC_OFFSET + radeon_crtc->crtc_offset, crtc_offset);
 	WREG32(RADEON_CRTC_PITCH + radeon_crtc->crtc_offset, crtc_pitch);
@@ -599,7 +599,7 @@ static bool radeon_set_crtc_timing(struct drm_crtc *crtc, struct drm_display_mod
 	case 8:
 		format = 2;
 		break;
@@ -1087,12 +1087,12 @@ static void radeon_crtc_commit(struct drm_crtc *crtc)
 static void radeon_crtc_disable(struct drm_crtc *crtc)
 	radeon_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
-	if (crtc->fb) {
 		int r;
 		if (unlikely(r))
diff --git a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
index fbf4be3..299267d 100644
--- a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
+++ b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
@@ -299,7 +299,7 @@ static void rcar_du_crtc_update_base(struct rcar_du_crtc *rcrtc)
 	struct drm_crtc *crtc = &rcrtc->crtc;
-	rcar_du_plane_compute_base(rcrtc->plane, crtc->fb);
+	rcar_du_plane_compute_base(rcrtc->plane, crtc->primary->fb);
 	rcar_du_plane_update_base(rcrtc->plane);
@@ -358,10 +358,10 @@ static int rcar_du_crtc_mode_set(struct drm_crtc *crtc,
 	const struct rcar_du_format_info *format;
 	int ret;
-	format = rcar_du_format_info(crtc->fb->pixel_format);
+	format = rcar_du_format_info(crtc->primary->fb->pixel_format);
 	if (format == NULL) {
 		dev_dbg(rcdu->dev, "mode_set: unsupported format %08x\n",
-			crtc->fb->pixel_format);
+			crtc->primary->fb->pixel_format);
 		ret = -EINVAL;
 		goto error;
@@ -377,7 +377,7 @@ static int rcar_du_crtc_mode_set(struct drm_crtc *crtc,
 	rcrtc->plane->width = mode->hdisplay;
 	rcrtc->plane->height = mode->vdisplay;
 	rcrtc->outputs = 0;
@@ -510,7 +510,7 @@ static int rcar_du_crtc_page_flip(struct drm_crtc *crtc,
-	crtc->fb = fb;
 	rcar_du_crtc_update_base(rcrtc);
 	if (event) {
diff --git a/drivers/gpu/drm/shmobile/shmob_drm_crtc.c b/drivers/gpu/drm/shmobile/shmob_drm_crtc.c
index ea543b4..e9e5e6d 100644
--- a/drivers/gpu/drm/shmobile/shmob_drm_crtc.c
+++ b/drivers/gpu/drm/shmobile/shmob_drm_crtc.c
@@ -173,7 +173,7 @@ static void shmob_drm_crtc_start(struct shmob_drm_crtc *scrtc)
 	if (scrtc->started)
 		return;
-	format = shmob_drm_format_info(crtc->fb->pixel_format);
+	format = shmob_drm_format_info(crtc->primary->fb->pixel_format);
 	if (WARN_ON(format == NULL))
 		return;
@@ -303,7 +303,7 @@ static void shmob_drm_crtc_compute_base(struct shmob_drm_crtc *scrtc,
 					int x, int y)
 	struct drm_crtc *crtc = &scrtc->crtc;
 	struct shmob_drm_device *sdev = crtc->dev->dev_private;
 	struct drm_gem_cma_object *gem;
 	unsigned int bpp;
@@ -382,15 +382,15 @@ static int shmob_drm_crtc_mode_set(struct drm_crtc *crtc,
 	const struct shmob_drm_format_info *format;
 	void *cache;
 		dev_dbg(sdev->dev, "mode_set: unsupported format %08x\n",
 		return -EINVAL;
 	scrtc->format = format;
-	scrtc->line_size = crtc->fb->pitches[0];
+	scrtc->line_size = crtc->primary->fb->pitches[0];
 	if (sdev->meram) {
 		/* Enable MERAM cache if configured. We need to de-init
@@ -402,7 +402,7 @@ static int shmob_drm_crtc_mode_set(struct drm_crtc *crtc,
 		cache = sh_mobile_meram_cache_alloc(sdev->meram, mdata,
-						    crtc->fb->pitches[0],
+						    crtc->primary->fb->pitches[0],
 						    adjusted_mode->vdisplay,
 						    format->meram,
 						    &scrtc->line_size);
@@ -489,7 +489,7 @@ static int shmob_drm_crtc_page_flip(struct drm_crtc *crtc,
-	crtc->fb = fb;
 	shmob_drm_crtc_update_base(scrtc);
 	if (event) {
diff --git a/drivers/gpu/drm/tegra/dc.c b/drivers/gpu/drm/tegra/dc.c
index 9336006..36c717a 100644
--- a/drivers/gpu/drm/tegra/dc.c
+++ b/drivers/gpu/drm/tegra/dc.c
@@ -235,14 +235,14 @@ static void tegra_dc_finish_page_flip(struct tegra_dc *dc)
 	if (!dc->event)
 		return;
-	bo = tegra_fb_get_plane(crtc->fb, 0);
+	bo = tegra_fb_get_plane(crtc->primary->fb, 0);
 	/* check if new start address has been latched */
 	tegra_dc_writel(dc, READ_MUX, DC_CMD_STATE_ACCESS);
 	base = tegra_dc_readl(dc, DC_WINBUF_START_ADDR);
 	tegra_dc_writel(dc, 0, DC_CMD_STATE_ACCESS);
-	if (base == bo->paddr + crtc->fb->offsets[0]) {
+	if (base == bo->paddr + crtc->primary->fb->offsets[0]) {
 		spin_lock_irqsave(&drm->event_lock, flags);
 		drm_send_vblank_event(drm, dc->pipe, dc->event);
 		drm_vblank_put(drm, dc->pipe);
@@ -284,7 +284,7 @@ static int tegra_dc_page_flip(struct drm_crtc *crtc, struct drm_framebuffer *fb,
 	tegra_dc_set_base(dc, 0, 0, fb);
-	crtc->fb = fb;
 	return 0;
@@ -645,7 +645,7 @@ static int tegra_crtc_mode_set(struct drm_crtc *crtc,
 			       struct drm_display_mode *adjusted,
 			       int x, int y, struct drm_framebuffer *old_fb)
-	struct tegra_bo *bo = tegra_fb_get_plane(crtc->fb, 0);
+	struct tegra_bo *bo = tegra_fb_get_plane(crtc->primary->fb, 0);
 	struct tegra_dc *dc = to_tegra_dc(crtc);
 	struct tegra_dc_window window;
 	unsigned long div, value;
@@ -682,9 +682,9 @@ static int tegra_crtc_mode_set(struct drm_crtc *crtc,
 	window.dst.y = 0;
 	window.dst.w = mode->hdisplay;
 	window.dst.h = mode->vdisplay;
-	window.format = tegra_dc_format(crtc->fb->pixel_format);
-	window.bits_per_pixel = crtc->fb->bits_per_pixel;
-	window.stride[0] = crtc->fb->pitches[0];
+	window.format = tegra_dc_format(crtc->primary->fb->pixel_format);
+	window.bits_per_pixel = crtc->primary->fb->bits_per_pixel;
+	window.stride[0] = crtc->primary->fb->pitches[0];
 	window.base[0] = bo->paddr;
 	err = tegra_dc_setup_window(dc, 0, &window);
@@ -699,7 +699,7 @@ static int tegra_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
-	return tegra_dc_set_base(dc, x, y, crtc->fb);
+	return tegra_dc_set_base(dc, x, y, crtc->primary->fb);
 static void tegra_crtc_prepare(struct drm_crtc *crtc)
diff --git a/drivers/gpu/drm/tilcdc/tilcdc_crtc.c b/drivers/gpu/drm/tilcdc/tilcdc_crtc.c
index d36efc1..d642d4a 100644
--- a/drivers/gpu/drm/tilcdc/tilcdc_crtc.c
+++ b/drivers/gpu/drm/tilcdc/tilcdc_crtc.c
@@ -74,7 +74,7 @@ static void set_scanout(struct drm_crtc *crtc, int n)
 		drm_flip_work_queue(&tilcdc_crtc->unref_work, tilcdc_crtc->scanout[n]);
 		drm_flip_work_commit(&tilcdc_crtc->unref_work, priv->wq);
-	tilcdc_crtc->scanout[n] = crtc->fb;
+	tilcdc_crtc->scanout[n] = crtc->primary->fb;
 	drm_framebuffer_reference(tilcdc_crtc->scanout[n]);
 	tilcdc_crtc->dirty &= ~stat[n];
 	pm_runtime_put_sync(dev->dev);
@@ -84,7 +84,7 @@ static void update_scanout(struct drm_crtc *crtc)
 	struct tilcdc_crtc *tilcdc_crtc = to_tilcdc_crtc(crtc);
 	unsigned int depth, bpp;
@@ -159,7 +159,7 @@ static int tilcdc_crtc_page_flip(struct drm_crtc *crtc,
 		return -EBUSY;
-	crtc->fb = fb;
 	tilcdc_crtc->event = event;
 	update_scanout(crtc);
@@ -339,7 +339,7 @@ static int tilcdc_crtc_mode_set(struct drm_crtc *crtc,
 	if (priv->rev == 2) {
-		drm_fb_get_bpp_depth(crtc->fb->pixel_format, &depth, &bpp);
+		drm_fb_get_bpp_depth(crtc->primary->fb->pixel_format, &depth, &bpp);
 		switch (bpp) {
 		case 16:
 			break;
diff --git a/drivers/gpu/drm/udl/udl_modeset.c b/drivers/gpu/drm/udl/udl_modeset.c
index 2ae1eb7..cddc4fc 100644
--- a/drivers/gpu/drm/udl/udl_modeset.c
+++ b/drivers/gpu/drm/udl/udl_modeset.c
@@ -310,7 +310,7 @@ static int udl_crtc_mode_set(struct drm_crtc *crtc,
-	struct udl_framebuffer *ufb = to_udl_fb(crtc->fb);
+	struct udl_framebuffer *ufb = to_udl_fb(crtc->primary->fb);
 	struct udl_device *udl = dev->dev_private;
 	char *buf;
 	char *wrptr;
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c b/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c
index 159af7e..a2dde5a 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c
@@ -468,7 +468,7 @@ static int do_surface_dirty_sou(struct vmw_private *dev_priv,
 	num_units = 0;
 	list_for_each_entry(crtc, &dev_priv->dev->mode_config.crtc_list,
 			    head) {
-		if (crtc->fb != &framebuffer->base)
+		if (crtc->primary->fb != &framebuffer->base)
 			continue;
 		units[num_units++] = vmw_crtc_to_du(crtc);
@@ -882,7 +882,7 @@ static int do_dmabuf_dirty_sou(struct drm_file *file_priv,
 	num_units = 0;
 	list_for_each_entry(crtc, &dev_priv->dev->mode_config.crtc_list, head) {
 			continue;
@@ -1243,7 +1243,7 @@ int vmw_kms_present(struct vmw_private *dev_priv,
 	num_units = 0;
-		if (crtc->fb != &vfb->base)
+		if (crtc->primary->fb != &vfb->base)
 			continue;
@@ -1380,7 +1380,7 @@ int vmw_kms_readback(struct vmw_private *dev_priv,
 	num_units = 0;
 			continue;
@@ -1723,7 +1723,7 @@ int vmw_du_page_flip(struct drm_crtc *crtc,
 		     uint32_t page_flip_flags)
 	struct vmw_private *dev_priv = vmw_priv(crtc->dev);
 	struct vmw_framebuffer *vfb = vmw_framebuffer_to_vfb(fb);
 	struct drm_file *file_priv ;
 	struct vmw_fence_obj *fence = NULL;
@@ -1741,7 +1741,7 @@ int vmw_du_page_flip(struct drm_crtc *crtc,
 	if (!vmw_kms_screen_object_flippable(dev_priv, crtc))
 		return -EINVAL;
-	crtc->fb = fb;
 	/* do a full screen dirty update */
 	clips.x1 = clips.y1 = 0;
@@ -1781,7 +1781,7 @@ int vmw_du_page_flip(struct drm_crtc *crtc,
 	return ret;
 out_no_fence:
 	return ret;
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c b/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c
index a055a26..b2b9bd2 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c
@@ -93,7 +93,7 @@ static int vmw_ldu_commit_list(struct vmw_private *dev_priv)
 		if (crtc == NULL)
 			return 0;
-		fb = entry->base.crtc.fb;
+		fb = entry->base.crtc.primary->fb;
 		return vmw_kms_write_svga(dev_priv, w, h, fb->pitches[0],
 					  fb->bits_per_pixel, fb->depth);
@@ -101,7 +101,7 @@ static int vmw_ldu_commit_list(struct vmw_private *dev_priv)
 	if (!list_empty(&lds->active)) {
 		entry = list_entry(lds->active.next, typeof(*entry), active);
 		vmw_kms_write_svga(dev_priv, fb->width, fb->height, fb->pitches[0],
@@ -259,7 +259,7 @@ static int vmw_ldu_crtc_set_config(struct drm_mode_set *set)
 		connector->encoder = NULL;
 		encoder->crtc = NULL;
-		crtc->fb = NULL;
 		crtc->enabled = false;
 		vmw_ldu_del_active(dev_priv, ldu);
@@ -280,7 +280,7 @@ static int vmw_ldu_crtc_set_config(struct drm_mode_set *set)
 	vmw_fb_off(dev_priv);
-	crtc->fb = fb;
 	encoder->crtc = crtc;
 	connector->encoder = encoder;
 	crtc->x = set->x;
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c b/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c
index 22406c8..a95d3a0 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c
@@ -307,7 +307,7 @@ static int vmw_sou_crtc_set_config(struct drm_mode_set *set)
-		crtc->fb = NULL;
 		crtc->x = 0;
 		crtc->y = 0;
@@ -368,7 +368,7 @@ static int vmw_sou_crtc_set_config(struct drm_mode_set *set)
-		crtc->fb = NULL;
 		crtc->x = 0;
 		crtc->y = 0;
@@ -381,7 +381,7 @@ static int vmw_sou_crtc_set_config(struct drm_mode_set *set)
 	crtc->mode = *mode;
-	crtc->fb = fb;
 	crtc->x = set->x;
 	crtc->y = set->y;
 	crtc->enabled = true;
@@ -572,5 +572,5 @@ void vmw_kms_screen_object_update_implicit_fb(struct vmw_private *dev_priv,
 	BUG_ON(!sou->base.is_implicit);
 	dev_priv->sou_priv->implicit_fb =
-		vmw_framebuffer_to_vfb(sou->base.crtc.fb);
+		vmw_framebuffer_to_vfb(sou->base.crtc.primary->fb);
diff --git a/drivers/staging/imx-drm/ipuv3-crtc.c b/drivers/staging/imx-drm/ipuv3-crtc.c
index 22be104..39a7519 100644
--- a/drivers/staging/imx-drm/ipuv3-crtc.c
+++ b/drivers/staging/imx-drm/ipuv3-crtc.c
@@ -120,7 +120,7 @@ static int ipu_page_flip(struct drm_crtc *crtc,
 	ipu_crtc->newfb = fb;
 	ipu_crtc->page_flip_event = event;
-	crtc->fb = fb;
 	return 0;
@@ -192,7 +192,7 @@ static int ipu_crtc_mode_set(struct drm_crtc *crtc,
 		return ret;
-	return ipu_plane_mode_set(ipu_crtc->plane[0], crtc, mode, crtc->fb,
+	return ipu_plane_mode_set(ipu_crtc->plane[0], crtc, mode, crtc->primary->fb,
 				  x, y, mode->hdisplay, mode->vdisplay);
@@ -218,7 +218,7 @@ static irqreturn_t ipu_irq_handler(int irq, void *dev_id)
 	if (ipu_crtc->newfb) {
 		ipu_crtc->newfb = NULL;
-		ipu_plane_set_base(ipu_crtc->plane[0], ipu_crtc->base.fb,
+		ipu_plane_set_base(ipu_crtc->plane[0], ipu_crtc->base.primary->fb,
 				ipu_crtc->plane[0]->x, ipu_crtc->plane[0]->y);
 		ipu_crtc_handle_pageflip(ipu_crtc);
BtrLinux
