staging: panel: replace del_timer by del_timer_sync
Use del_timer_sync to ensure that the timer is stopped on all CPUs before
the driver exists.
This change was suggested by Thomas Gleixner.
(http://coccinelle.lip6.fr/)
@r@
declarer name module_exit;
identifier ex;
module_exit(ex);
identifier r.ex;
ex(...) {
- del_timer
+ del_timer_sync
Signed-off-by: Julia Lawall
 drivers/staging/panel/panel.c | 2 +-
diff --git a/drivers/staging/panel/panel.c b/drivers/staging/panel/panel.c
index 08f9a48..a53f94e 100644
--- a/drivers/staging/panel/panel.c
+++ b/drivers/staging/panel/panel.c
@@ -2298,7 +2298,7 @@ static void __exit panel_cleanup_module(void)
 	unregister_reboot_notifier(&panel_notifier);
 	if (scan_timer.function != NULL)
-		del_timer(&scan_timer);
+		del_timer_sync(&scan_timer);
 	if (pprt != NULL) {
 		if (keypad_enabled) {
BtrLinux
