iommu/fsl: Add void declarations in zero-arg functions.
Author: Chi Pham <fempsci@gmail.com>
Added explicit void declarations to zero-argument function headers.
The following coccinelle script was used:
@addvoid@
identifier f;
f(
+ void
Signed-off-by: Chi Pham
Signed-off-by: Joerg Roedel
 drivers/iommu/fsl_pamu.c        | 2 +-
 drivers/iommu/fsl_pamu_domain.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/iommu/fsl_pamu.c b/drivers/iommu/fsl_pamu.c
index b99dd88..5c9b424 100644
--- a/drivers/iommu/fsl_pamu.c
+++ b/drivers/iommu/fsl_pamu.c
@@ -92,7 +92,7 @@ struct gen_pool *spaace_pool;
  * subwindow count per liodn.
-u32 pamu_get_max_subwin_cnt()
+u32 pamu_get_max_subwin_cnt(void)
 	return max_subwindow_count;
diff --git a/drivers/iommu/fsl_pamu_domain.c b/drivers/iommu/fsl_pamu_domain.c
index 0009dff..8f42e8e 100644
--- a/drivers/iommu/fsl_pamu_domain.c
+++ b/drivers/iommu/fsl_pamu_domain.c
@@ -1156,7 +1156,7 @@ static struct iommu_ops fsl_pamu_ops = {
 	.remove_device	= fsl_pamu_remove_device,
-int pamu_domain_init()
+int pamu_domain_init(void)
 	int ret = 0;
BtrLinux
