[media] drivers/media: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
    when strict
return
- ret
+ C
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/pci/ngene/ngene-core.c      |  7 ++-----
 drivers/media/usb/cx231xx/cx231xx-video.c | 11 +++++------
 2 files changed, 7 insertions(+), 11 deletions(-)
diff --git a/drivers/media/pci/ngene/ngene-core.c b/drivers/media/pci/ngene/ngene-core.c
index 970e833..826228c 100644
--- a/drivers/media/pci/ngene/ngene-core.c
+++ b/drivers/media/pci/ngene/ngene-core.c
@@ -910,7 +910,6 @@ static int AllocateRingBuffers(struct pci_dev *pci_dev,
 	dma_addr_t tmp;
 	u32 i, j;
-	int status = 0;
 	u32 SCListMemSize = pRingBuffer->NumBuffers
 		* ((Buffer2Length != 0) ? (NUM_SCATTER_GATHER_ENTRIES * 2) :
 		    NUM_SCATTER_GATHER_ENTRIES)
@@ -1010,14 +1009,12 @@ static int AllocateRingBuffers(struct pci_dev *pci_dev,
-	return status;
+	return 0;
 static int FillTSIdleBuffer(struct SRingBufferDescriptor *pIdleBuffer,
 			    struct SRingBufferDescriptor *pRingBuffer)
-	int status = 0;
 	/* Copy pointer to scatter gather list in TSRingbuffer
 	   structure for buffer 2
 	   Load number of buffer
@@ -1038,7 +1035,7 @@ static int FillTSIdleBuffer(struct SRingBufferDescriptor *pIdleBuffer,
 			pIdleBuffer->Head->ngeneBuffer.Number_of_entries_1;
 		Cur = Cur->Next;
-	return status;
+	return 0;
 static u32 RingBufferSizes[MAX_STREAM] = {
diff --git a/drivers/media/usb/cx231xx/cx231xx-video.c b/drivers/media/usb/cx231xx/cx231xx-video.c
index 1f87513..cba7fea 100644
--- a/drivers/media/usb/cx231xx/cx231xx-video.c
+++ b/drivers/media/usb/cx231xx/cx231xx-video.c
@@ -208,7 +208,7 @@ static inline void get_next_buf(struct cx231xx_dmaqueue *dma_q,
 static inline int cx231xx_isoc_copy(struct cx231xx *dev, struct urb *urb)
 	struct cx231xx_dmaqueue *dma_q = urb->context;
-	int i, rc = 1;
+	int i;
 	unsigned char *p_buffer;
 	u32 bytes_parsed = 0, buffer_size = 0;
 	u8 sav_eav = 0;
@@ -299,13 +299,12 @@ static inline int cx231xx_isoc_copy(struct cx231xx *dev, struct urb *urb)
 		bytes_parsed = 0;
-	return rc;
+	return 1;
 static inline int cx231xx_bulk_copy(struct cx231xx *dev, struct urb *urb)
-	int rc = 1;
 	u8 sav_eav = 0;
@@ -379,7 +378,7 @@ static inline int cx231xx_bulk_copy(struct cx231xx *dev, struct urb *urb)
 		bytes_parsed = 0;
-	return rc;
+	return 1;
@@ -1620,7 +1619,7 @@ static int radio_s_tuner(struct file *file, void *priv, const struct v4l2_tuner
 static int cx231xx_v4l2_open(struct file *filp)
-	int errCode = 0, radio = 0;
+	int radio = 0;
 	struct video_device *vdev = video_devdata(filp);
 	struct cx231xx *dev = video_drvdata(filp);
 	struct cx231xx_fh *fh;
@@ -1718,7 +1717,7 @@ static int cx231xx_v4l2_open(struct file *filp)
 	mutex_unlock(&dev->lock);
 	v4l2_fh_add(&fh->fh);
-	return errCode;
+	return 0;
BtrLinux
