brcmfmac: fix memory leakage in msgbuf
Author: Arend van Spriel <arend@broadcom.com>
The kbuild robot came up with the following warning:
tree:   .../kernel/git/linville/wireless-next.git master
head:   dc6be9f54a4ecb0a09765d1f515ed947d86b7528
commit: 9a1bb60250d2b6b546a62e5b73f55c4f1d22016b
	 [5/13] brcmfmac: Adding msgbuf protocol.
coccinelle warnings:
 drivers/net/wireless/brcm80211/brcmfmac/msgbuf.c:1309:1-28:
   alloc with no test, possible model on line 1318
Looking into the issue, it turned out that the referred allocation
buffer was not being released in failure path nor upon module
unload.
Reported-by: Fengguang Wu
Reviewed-by: Franky (Zhenhui) Lin
Reviewed-by: Daniel (Deognyoun) Kim
Reviewed-by: Pieter-Paul Giesberts
Signed-off-by: Arend van Spriel
Signed-off-by: John W. Linville
 drivers/net/wireless/brcm80211/brcmfmac/msgbuf.c | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/drivers/net/wireless/brcm80211/brcmfmac/msgbuf.c b/drivers/net/wireless/brcm80211/brcmfmac/msgbuf.c
index 535c7eb..8f8b937 100644
--- a/drivers/net/wireless/brcm80211/brcmfmac/msgbuf.c
+++ b/drivers/net/wireless/brcm80211/brcmfmac/msgbuf.c
@@ -1318,6 +1318,8 @@ int brcmf_proto_msgbuf_attach(struct brcmf_pub *drvr)
 	msgbuf->nrof_flowrings = if_msgbuf->nrof_flowrings;
 	msgbuf->flowring_dma_handle = kzalloc(msgbuf->nrof_flowrings *
 		sizeof(*msgbuf->flowring_dma_handle), GFP_ATOMIC);
+	if (!msgbuf->flowring_dma_handle)
+		goto fail;
 	msgbuf->rx_dataoffset = if_msgbuf->rx_dataoffset;
 	msgbuf->max_rxbufpost = if_msgbuf->max_rxbufpost;
@@ -1362,6 +1364,7 @@ fail:
 		kfree(msgbuf->flow_map);
 		kfree(msgbuf->txstatus_done_map);
 		brcmf_msgbuf_release_pktids(msgbuf);
+		kfree(msgbuf->flowring_dma_handle);
 		if (msgbuf->ioctbuf)
 			dma_free_coherent(drvr->bus_if->dev,
 					  BRCMF_TX_IOCTL_MAX_MSG_SIZE,
@@ -1391,6 +1394,7 @@ void brcmf_proto_msgbuf_detach(struct brcmf_pub *drvr)
 				  msgbuf->ioctbuf, msgbuf->ioctbuf_handle);
 		kfree(msgbuf);
 		drvr->proto->pd = NULL;
BtrLinux
