lustre: obdclass: use c99 initializers in structures
Use c99 initializers for structures.
@decl@
identifier i1,fld;
type T;
field list[n] fs;
struct i1 {
fs
T fld;
@bad@
identifier decl.i1,i2;
expression e;
initializer list[decl.n] is;
struct i1 i2 = { is,
+ .fld = e
- e
Signed-off-by: Julia Lawall
drivers/staging/lustre/lustre/obdclass/lprocfs_status.c | 5 ++++-
drivers/staging/lustre/lustre/obdclass/obd_mount.c | 5 ++++-
2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
index 1dbb309..8ca9afc 100644
--- a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
+++ b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
@@ -1572,7 +1572,10 @@ lproc_exp_hash_seq_show(struct seq_file *m, void *unused)
struct nid_stat *stats = (struct nid_stat *)m->private;
struct obd_device *obd = stats->nid_obd;
- struct exp_hash_cb_data cb_data = {m, true};
+ struct exp_hash_cb_data cb_data = {
+ .m = m,
+ .first = true
cfs_hash_for_each_key(obd->obd_nid_hash, &stats->nid,
lprocfs_exp_print_hash, &cb_data);
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_mount.c b/drivers/staging/lustre/lustre/obdclass/obd_mount.c
index 560a47d..9653b38 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_mount.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_mount.c
@@ -1276,7 +1276,10 @@ EXPORT_SYMBOL(lustre_register_kill_super_cb);
struct dentry *lustre_mount(struct file_system_type *fs_type, int flags,
const char *devname, void *data)
- struct lustre_mount_data2 lmd2 = { data, NULL };
+ struct lustre_mount_data2 lmd2 = {
+ .lmd2_data = data,
+ .lmd2_mnt = NULL
return mount_nodev(fs_type, flags, &lmd2, lustre_fill_super);
+ .m = m,
+ .first = true
+ .lmd2_mnt = NULL
