host: ehci-w90x900: fix error return code
Return a negative error code on failure.
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
 drivers/usb/host/ehci-w90x900.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-w90x900.c b/drivers/usb/host/ehci-w90x900.c
index 4717bf2..c305732 100644
--- a/drivers/usb/host/ehci-w90x900.c
+++ b/drivers/usb/host/ehci-w90x900.c
@@ -75,8 +75,10 @@ static int usb_w90x900_probe(const struct hc_driver *driver,
 	__raw_writel(val, ehci->regs+PHY1_CTR);
 	irq = platform_get_irq(pdev, 0);
-	if (irq < 0)
+	if (irq < 0) {
+		retval = irq;
 		goto err2;
 	retval = usb_add_hcd(hcd, irq, IRQF_SHARED);
 	if (retval != 0)
BtrLinux
