ASoC: cs35l33: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <lkp@intel.com>
sound/soc/codecs/cs35l33.c:1301:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Mark Brown
sound/soc/codecs/cs35l33.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/sound/soc/codecs/cs35l33.c b/sound/soc/codecs/cs35l33.c
index 841374a..55c1f75 100644
--- a/sound/soc/codecs/cs35l33.c
+++ b/sound/soc/codecs/cs35l33.c
@@ -1298,7 +1298,6 @@ MODULE_DEVICE_TABLE(i2c, cs35l33_id);
static struct i2c_driver cs35l33_i2c_driver = {
.driver = {
.name = "cs35l33",
- .owner = THIS_MODULE,
.pm = &cs35l33_pm_ops,
.of_match_table = cs35l33_of_match, |
.driver = {
.name = "cs35l33",
