drivers/staging/lustre/lustre/obdclass/class_obd.c | 2 +-
drivers/staging/lustre/lustre/obdclass/genops.c | 6 +++---
drivers/staging/lustre/lustre/obdclass/llog.c | 6 +++---
drivers/staging/lustre/lustre/obdclass/lprocfs_status.c | 2 +-
drivers/staging/lustre/lustre/obdclass/lustre_peer.c | 2 +-
drivers/staging/lustre/lustre/obdclass/obd_config.c | 10 +++++-----
drivers/staging/lustre/lustre/obdclass/obd_mount.c | 12 ++++++------
7 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/class_obd.c b/drivers/staging/lustre/lustre/obdclass/class_obd.c
index 1bc3756..8ebe2e6 100644
--- a/drivers/staging/lustre/lustre/obdclass/class_obd.c
+++ b/drivers/staging/lustre/lustre/obdclass/class_obd.c
@@ -232,7 +232,7 @@ int class_handle_ioctl(unsigned int cmd, unsigned long arg)
goto out;
lcfg = kzalloc(data->ioc_plen1, GFP_NOFS);
- if (lcfg == NULL) {
+ if (!lcfg) {
err = -ENOMEM;
goto out;
diff --git a/drivers/staging/lustre/lustre/obdclass/genops.c b/drivers/staging/lustre/lustre/obdclass/genops.c
index 978c3c5..a42c9f9 100644
--- a/drivers/staging/lustre/lustre/obdclass/genops.c
+++ b/drivers/staging/lustre/lustre/obdclass/genops.c
@@ -172,7 +172,7 @@ int class_register_type(struct obd_ops *dt_ops, struct md_ops *md_ops,
rc = -ENOMEM;
type = kzalloc(sizeof(*type), GFP_NOFS);
- if (type == NULL)
+ if (!type)
return rc;
type->typ_dt_ops = kzalloc(sizeof(*type->typ_dt_ops), GFP_NOFS);
@@ -1016,7 +1016,7 @@ struct obd_import *class_new_import(struct obd_device *obd)
struct obd_import *imp;
imp = kzalloc(sizeof(*imp), GFP_NOFS);
- if (imp == NULL)
+ if (!imp)
return NULL;
INIT_LIST_HEAD(&imp->imp_pinger_chain);
@@ -1819,7 +1819,7 @@ void *kuc_alloc(int payload_len, int transport, int type)
int len = kuc_len(payload_len);
lh = kzalloc(len, GFP_NOFS);
- if (lh == NULL)
+ if (!lh)
return ERR_PTR(-ENOMEM);
lh->kuc_magic = KUC_MAGIC;
diff --git a/drivers/staging/lustre/lustre/obdclass/llog.c b/drivers/staging/lustre/lustre/obdclass/llog.c
index 4fa52d1..9af2da6 100644
--- a/drivers/staging/lustre/lustre/obdclass/llog.c
+++ b/drivers/staging/lustre/lustre/obdclass/llog.c
@@ -61,7 +61,7 @@ static struct llog_handle *llog_alloc_handle(void)
struct llog_handle *loghandle;
loghandle = kzalloc(sizeof(*loghandle), GFP_NOFS);
- if (loghandle == NULL)
+ if (!loghandle)
return NULL;
init_rwsem(&loghandle->lgh_lock);
@@ -208,7 +208,7 @@ int llog_init_handle(const struct lu_env *env, struct llog_handle *handle,
LASSERT(handle->lgh_hdr == NULL);
llh = kzalloc(sizeof(*llh), GFP_NOFS);
- if (llh == NULL)
+ if (!llh)
return -ENOMEM;
handle->lgh_hdr = llh;
/* first assign flags to use llog_client_ops */
@@ -435,7 +435,7 @@ int llog_process_or_fork(const struct lu_env *env,
int rc;
lpi = kzalloc(sizeof(*lpi), GFP_NOFS);
- if (lpi == NULL) {
+ if (!lpi) {
CERROR("cannot alloc pointer\n");
return -ENOMEM;
diff --git a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
index 17e7c18..c761dbf 100644
--- a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
+++ b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
@@ -275,7 +275,7 @@ struct dentry *ldebugfs_add_symlink(const char *name, struct dentry *parent,
return NULL;
dest = kzalloc(MAX_STRING_SIZE + 1, GFP_KERNEL);
- if (dest == NULL)
+ if (!dest)
return NULL;
va_start(ap, format);
diff --git a/drivers/staging/lustre/lustre/obdclass/lustre_peer.c b/drivers/staging/lustre/lustre/obdclass/lustre_peer.c
index 5cc6435..d6184f8 100644
--- a/drivers/staging/lustre/lustre/obdclass/lustre_peer.c
+++ b/drivers/staging/lustre/lustre/obdclass/lustre_peer.c
@@ -105,7 +105,7 @@ int class_add_uuid(const char *uuid, __u64 nid)
return -EOVERFLOW;
data = kzalloc(sizeof(*data), GFP_NOFS);
- if (data == NULL)
+ if (!data)
return -ENOMEM;
obd_str2uuid(&data->un_uuid, uuid);
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_config.c b/drivers/staging/lustre/lustre/obdclass/obd_config.c
index fbdb748..3435720 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_config.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_config.c
@@ -835,7 +835,7 @@ int class_add_profile(int proflen, char *prof, int osclen, char *osc,
CDEBUG(D_CONFIG, "Add profile %s\n", prof);
lprof = kzalloc(sizeof(*lprof), GFP_NOFS);
- if (lprof == NULL)
+ if (!lprof)
return -ENOMEM;
INIT_LIST_HEAD(&lprof->lp_list);
@@ -979,7 +979,7 @@ struct lustre_cfg *lustre_cfg_rename(struct lustre_cfg *cfg,
new_len = LUSTRE_CFG_BUFLEN(cfg, 1) + strlen(new_name) - name_len;
new_param = kzalloc(new_len, GFP_NOFS);
- if (new_param == NULL)
+ if (!new_param)
strcpy(new_param, new_name);
@@ -987,7 +987,7 @@ struct lustre_cfg *lustre_cfg_rename(struct lustre_cfg *cfg,
strcat(new_param, value);
bufs = kzalloc(sizeof(*bufs), GFP_NOFS);
- if (bufs == NULL) {
+ if (!bufs) {
kfree(new_param);
@@ -1461,7 +1461,7 @@ int class_config_llog_handler(const struct lu_env *env,
inst_len = LUSTRE_CFG_BUFLEN(lcfg, 0) +
sizeof(clli->cfg_instance) * 2 + 4;
inst_name = kzalloc(inst_len, GFP_NOFS);
- if (inst_name == NULL) {
+ if (!inst_name) {
rc = -ENOMEM;
goto out;
@@ -1639,7 +1639,7 @@ int class_config_dump_handler(const struct lu_env *env,
int rc = 0;
outstr = kzalloc(256, GFP_NOFS);
- if (outstr == NULL)
+ if (!outstr)
return -ENOMEM;
if (rec->lrh_type == OBD_CFG_REC) {
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_mount.c b/drivers/staging/lustre/lustre/obdclass/obd_mount.c
index ce4a71f..3e0b8a4 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_mount.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_mount.c
@@ -85,7 +85,7 @@ int lustre_process_log(struct super_block *sb, char *logname,
LASSERT(cfg);
- if (bufs == NULL)
+ if (!bufs)
return -ENOMEM;
/* mgc_process_config */
@@ -258,7 +258,7 @@ int lustre_start_mgc(struct super_block *sb)
mgssec = lsi->lsi_lmd->lmd_mgssec ? lsi->lsi_lmd->lmd_mgssec : "";
- if (data == NULL) {
+ if (!data) {
rc = -ENOMEM;
goto out_free;
@@ -885,7 +885,7 @@ static int lmd_parse_mgssec(struct lustre_mount_data *lmd, char *ptr)
length = tail - ptr;
lmd->lmd_mgssec = kzalloc(length + 1, GFP_NOFS);
- if (lmd->lmd_mgssec == NULL)
+ if (!lmd->lmd_mgssec)
return -ENOMEM;
memcpy(lmd->lmd_mgssec, ptr, length);
@@ -911,7 +911,7 @@ static int lmd_parse_string(char **handle, char *ptr)
*handle = kzalloc(length + 1, GFP_NOFS);
- if (*handle == NULL)
+ if (!*handle)
return -ENOMEM;
memcpy(*handle, ptr, length);
@@ -941,7 +941,7 @@ static int lmd_parse_mgs(struct lustre_mount_data *lmd, char **ptr)
oldlen = strlen(lmd->lmd_mgs) + 1;
mgsnid = kzalloc(oldlen + length + 1, GFP_NOFS);
- if (mgsnid == NULL)
+ if (!mgsnid)
return -ENOMEM;
if (lmd->lmd_mgs != NULL) {
@@ -983,7 +983,7 @@ static int lmd_parse(char *options, struct lustre_mount_data *lmd)
lmd->lmd_magic = LMD_MAGIC;
lmd->lmd_params = kzalloc(4096, GFP_NOFS);
- if (lmd->lmd_params == NULL)
+ if (!lmd->lmd_params)
return -ENOMEM;
lmd->lmd_params[0] = '\0'; |
