avr32/at32ap: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Signed-off-by: Thomas Gleixner
Acked-by: Hans-Christian Egtvedt
Cc: Haavard Skinnemoen
Cc: Jiang Liu
Cc: Julia Lawall
Link: http://lkml.kernel.org/r/20150713100606.448031045@linutronix.de
 arch/avr32/mach-at32ap/extint.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/avr32/mach-at32ap/extint.c b/arch/avr32/mach-at32ap/extint.c
index 2d48b6a..d51ff8f 100644
--- a/arch/avr32/mach-at32ap/extint.c
+++ b/arch/avr32/mach-at32ap/extint.c
@@ -128,9 +128,9 @@ static int eic_set_irq_type(struct irq_data *d, unsigned int flow_type)
 	irqd_set_trigger_type(d, flow_type);
 	if (flow_type & (IRQ_TYPE_LEVEL_LOW | IRQ_TYPE_LEVEL_HIGH))
-		__irq_set_handler_locked(irq, handle_level_irq);
+		irq_set_handler_locked(d, handle_level_irq);
 	else
-		__irq_set_handler_locked(irq, handle_edge_irq);
+		irq_set_handler_locked(d, handle_edge_irq);
 	return IRQ_SET_MASK_OK_NOCOPY;
BtrLinux
