m68k/irq: Prepare irq handlers for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Geert Uytterhoeven
Cc: linux-m68k@lists.linux-m68k.org
 arch/m68k/coldfire/intc-5272.c | 4 +++-
 arch/m68k/mac/oss.c            | 6 ++++--
 arch/m68k/mac/psc.c            | 3 ++-
 3 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/arch/m68k/coldfire/intc-5272.c b/arch/m68k/coldfire/intc-5272.c
index d1e2fba..47371de 100644
--- a/arch/m68k/coldfire/intc-5272.c
+++ b/arch/m68k/coldfire/intc-5272.c
@@ -143,8 +143,10 @@ static int intc_irq_set_type(struct irq_data *d, unsigned int type)
  * We need to be careful with the masking/acking due to the side effects
  * of masking an interrupt.
-static void intc_external_irq(unsigned int irq, struct irq_desc *desc)
+static void intc_external_irq(unsigned int __irq, struct irq_desc *desc)
+	unsigned int irq = irq_desc_get_irq(desc);
 	irq_desc_get_chip(desc)->irq_ack(&desc->irq_data);
 	handle_simple_irq(irq, desc);
diff --git a/arch/m68k/mac/oss.c b/arch/m68k/mac/oss.c
index bb11dce..191610d 100644
--- a/arch/m68k/mac/oss.c
+++ b/arch/m68k/mac/oss.c
@@ -63,13 +63,15 @@ void __init oss_nubus_init(void)
  * Handle miscellaneous OSS interrupts.
-static void oss_irq(unsigned int irq, struct irq_desc *desc)
+static void oss_irq(unsigned int __irq, struct irq_desc *desc)
 	int events = oss->irq_pending &
-	             (OSS_IP_IOPSCC | OSS_IP_SCSI | OSS_IP_IOPISM);
+		(OSS_IP_IOPSCC | OSS_IP_SCSI | OSS_IP_IOPISM);
 #ifdef DEBUG_IRQS
 	if ((console_loglevel == 10) && !(events & OSS_IP_SCSI)) {
 		printk("oss_irq: irq %u events = 0x%04X\n", irq,
 			(int) oss->irq_pending);
diff --git a/arch/m68k/mac/psc.c b/arch/m68k/mac/psc.c
index 272dde4..3b9e302 100644
--- a/arch/m68k/mac/psc.c
+++ b/arch/m68k/mac/psc.c
@@ -113,9 +113,10 @@ void __init psc_init(void)
  * PSC interrupt handler. It's a lot like the VIA interrupt handler.
-static void psc_irq(unsigned int irq, struct irq_desc *desc)
+static void psc_irq(unsigned int __irq, struct irq_desc *desc)
 	unsigned int offset = (unsigned int)irq_desc_get_handler_data(desc);
 	int pIFR	= pIFRbase + offset;
 	int pIER	= pIERbase + offset;
 	int irq_num;
BtrLinux
