ASoC: alc5632: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/alc5632.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/alc5632.c b/sound/soc/codecs/alc5632.c
index 607a63b..1cabb40 100644
--- a/sound/soc/codecs/alc5632.c
+++ b/sound/soc/codecs/alc5632.c
@@ -146,11 +146,10 @@ static const DECLARE_TLV_DB_SCALE(vol_tlv, -3450, 150, 0);
 static const DECLARE_TLV_DB_SCALE(hp_tlv, -4650, 150, 0);
 /* -16.5db min scale, 1.5db steps, no mute */
 static const DECLARE_TLV_DB_SCALE(adc_rec_tlv, -1650, 150, 0);
-static const unsigned int boost_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(boost_tlv,
 	0, 1, TLV_DB_SCALE_ITEM(0, 2000, 0),
-	1, 3, TLV_DB_SCALE_ITEM(2000, 1000, 0),
+	1, 3, TLV_DB_SCALE_ITEM(2000, 1000, 0)
 /* 0db min scale, 6 db steps, no mute */
 static const DECLARE_TLV_DB_SCALE(dig_tlv, 0, 600, 0);
 /* 0db min scalem 0.75db steps, no mute */
BtrLinux
