iio: light: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/iio/light/opt3001.c:796:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Andreas Dannenberg
Signed-off-by: Fengguang Wu
Signed-off-by: Jonathan Cameron
 drivers/iio/light/opt3001.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/iio/light/opt3001.c b/drivers/iio/light/opt3001.c
index 923aa6a..01e111e 100644
--- a/drivers/iio/light/opt3001.c
+++ b/drivers/iio/light/opt3001.c
@@ -793,7 +793,6 @@ static struct i2c_driver opt3001_driver = {
 	.driver = {
 		.name = "opt3001",
 		.of_match_table = of_match_ptr(opt3001_of_match),
-		.owner = THIS_MODULE,
BtrLinux
