powerpc/mpc52xx: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle:
struct irq_data *d;
expression E1;
-__irq_set_handler_locked(d->irq, E1);
+irq_set_handler_locked(d, E1);
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Anatolij Gustschin
Cc: Benjamin Herrenschmidt
Cc: Paul Mackerras
Cc: Michael Ellerman
Cc: linuxppc-dev@lists.ozlabs.org
 arch/powerpc/platforms/52xx/mpc52xx_pic.c | 2 +-
diff --git a/arch/powerpc/platforms/52xx/mpc52xx_pic.c b/arch/powerpc/platforms/52xx/mpc52xx_pic.c
index 2944bc8..4fe2074 100644
--- a/arch/powerpc/platforms/52xx/mpc52xx_pic.c
+++ b/arch/powerpc/platforms/52xx/mpc52xx_pic.c
@@ -196,7 +196,7 @@ static int mpc52xx_extirq_set_type(struct irq_data *d, unsigned int flow_type)
 	ctrl_reg |= (type << (22 - (l2irq * 2)));
 	out_be32(&intr->ctrl, ctrl_reg);
-	__irq_set_handler_locked(d->irq, handler);
+	irq_set_handler_locked(d, handler);
 	return 0;
BtrLinux
