usb: whci: fhci: remove comparison to bool
Author: Geyslan G. Bem <geyslan@gmail.com>
Get rid of bool explicit comparisons.
Caught by Coccinelle.
Signed-off-by: Geyslan G. Bem
 drivers/usb/host/fhci-tds.c  | 2 +-
 drivers/usb/host/whci/qset.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/fhci-tds.c b/drivers/usb/host/fhci-tds.c
index 1498061..f82ad5d 100644
--- a/drivers/usb/host/fhci-tds.c
+++ b/drivers/usb/host/fhci-tds.c
@@ -85,7 +85,7 @@ static struct usb_td __iomem *next_bd(struct usb_td __iomem *base,
 void fhci_push_dummy_bd(struct endpoint *ep)
-	if (ep->already_pushed_dummy_bd == false) {
+	if (!ep->already_pushed_dummy_bd) {
 		u16 td_status = in_be16(&ep->empty_td->status);
 		out_be32(&ep->empty_td->buf_ptr, DUMMY_BD_BUFFER);
diff --git a/drivers/usb/host/whci/qset.c b/drivers/usb/host/whci/qset.c
index 3297473..5e48a60 100644
--- a/drivers/usb/host/whci/qset.c
+++ b/drivers/usb/host/whci/qset.c
@@ -395,7 +395,7 @@ static void urb_dequeue_work(struct work_struct *work)
 	struct whc *whc = qset->whc;
 	unsigned long flags;
-	if (wurb->is_async == true)
+	if (wurb->is_async)
 		asl_update(whc, WUSBCMD_ASYNC_UPDATED
 			   | WUSBCMD_ASYNC_SYNCED_DB
 			   | WUSBCMD_ASYNC_QSET_RM);
BtrLinux
