power: bq2415x_charger: Delete unnecessary checks before the function call « of_node_put »
Author: Markus Elfring <elfring@users.sourceforge.net>
The of_node_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Acked-by: Pali Rohár
Signed-off-by: Sebastian Reichel
 drivers/power/bq2415x_charger.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/power/bq2415x_charger.c b/drivers/power/bq2415x_charger.c
index 4afd768..27e8953 100644
--- a/drivers/power/bq2415x_charger.c
+++ b/drivers/power/bq2415x_charger.c
@@ -1704,7 +1704,7 @@ error_4:
 error_3:
 	bq2415x_power_supply_exit(bq);
 error_2:
-	if (bq && bq->notify_node)
+	if (bq)
 		of_node_put(bq->notify_node);
 	kfree(name);
 error_1:
@@ -1724,9 +1724,7 @@ static int bq2415x_remove(struct i2c_client *client)
 	if (bq->nb.notifier_call)
 		power_supply_unreg_notifier(&bq->nb);
-	if (bq->notify_node)
-		of_node_put(bq->notify_node);
+	of_node_put(bq->notify_node);
 	bq2415x_sysfs_exit(bq);
BtrLinux
