drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c | 8 ++++----
drivers/staging/rtl8192e/rtl8192e/rtl_dm.c | 2 +-
drivers/staging/rtl8192e/rtl819x_BAProc.c | 6 +++---
drivers/staging/rtl8192e/rtllib_rx.c | 2 +-
drivers/staging/rtl8192e/rtllib_softmac.c | 2 +-
drivers/staging/rtl8192e/rtllib_softmac_wx.c | 2 +-
6 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c b/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c
index e9c4f97..ba64a4f 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c
@@ -680,7 +680,7 @@ static void _rtl92e_hwconfig(struct net_device *dev)
rtl92e_writeb(dev, BW_OPMODE, regBwOpMode);
- u32 ratr_value = 0;
+ u32 ratr_value;
ratr_value = regRATR;
if (priv->rf_type == RF_1T2R)
@@ -1000,7 +1000,7 @@ void rtl92e_link_change(struct net_device *dev)
_rtl92e_update_msr(dev);
if (ieee->iw_mode == IW_MODE_INFRA || ieee->iw_mode == IW_MODE_ADHOC) {
- u32 reg = 0;
+ u32 reg;
reg = rtl92e_readl(dev, RCR);
if (priv->rtllib->state == RTLLIB_LINKED) {
@@ -1186,7 +1186,7 @@ void rtl92e_fill_tx_desc(struct net_device *dev, struct tx_desc *pdesc,
struct r8192_priv *priv = rtllib_priv(dev);
dma_addr_t mapping = pci_map_single(priv->pdev, skb->data, skb->len,
PCI_DMA_TODEVICE);
- struct tx_fwinfo_8190pci *pTxFwInfo = NULL;
+ struct tx_fwinfo_8190pci *pTxFwInfo;
pTxFwInfo = (struct tx_fwinfo_8190pci *)skb->data;
memset(pTxFwInfo, 0, sizeof(struct tx_fwinfo_8190pci));
@@ -2235,7 +2235,7 @@ void rtl92e_disable_irq(struct net_device *dev)
void rtl92e_clear_irq(struct net_device *dev)
- u32 tmp = 0;
+ u32 tmp;
tmp = rtl92e_readl(dev, ISR);
rtl92e_writel(dev, ISR, tmp);
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c b/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c
index ef03242..b6b714d 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c
@@ -1875,7 +1875,7 @@ void rtl92e_dm_rf_pathcheck_wq(void *data)
struct r8192_priv,
rfpath_check_wq);
struct net_device *dev = priv->rtllib->dev;
- u8 rfpath = 0, i;
+ u8 rfpath, i;
rfpath = rtl92e_readb(dev, 0xc04);
diff --git a/drivers/staging/rtl8192e/rtl819x_BAProc.c b/drivers/staging/rtl8192e/rtl819x_BAProc.c
index c04a020..c7fd1b1 100644
--- a/drivers/staging/rtl8192e/rtl819x_BAProc.c
+++ b/drivers/staging/rtl8192e/rtl819x_BAProc.c
@@ -189,7 +189,7 @@ static struct sk_buff *rtllib_DELBA(struct rtllib_device *ieee, u8 *dst,
static void rtllib_send_ADDBAReq(struct rtllib_device *ieee, u8 *dst,
struct ba_record *pBA)
- struct sk_buff *skb = NULL;
+ struct sk_buff *skb;
skb = rtllib_ADDBA(ieee, dst, pBA, 0, ACT_ADDBAREQ);
@@ -204,7 +204,7 @@ static void rtllib_send_ADDBAReq(struct rtllib_device *ieee, u8 *dst,
static void rtllib_send_ADDBARsp(struct rtllib_device *ieee, u8 *dst,
struct ba_record *pBA, u16 StatusCode)
skb = rtllib_ADDBA(ieee, dst, pBA, StatusCode, ACT_ADDBARSP);
if (skb)
@@ -217,7 +217,7 @@ static void rtllib_send_DELBA(struct rtllib_device *ieee, u8 *dst,
struct ba_record *pBA, enum tr_select TxRxSelect,
u16 ReasonCode)
skb = rtllib_DELBA(ieee, dst, pBA, TxRxSelect, ReasonCode);
if (skb)
diff --git a/drivers/staging/rtl8192e/rtllib_rx.c b/drivers/staging/rtl8192e/rtllib_rx.c
index 37343ec..af64bd3 100644
--- a/drivers/staging/rtl8192e/rtllib_rx.c
+++ b/drivers/staging/rtl8192e/rtllib_rx.c
@@ -905,7 +905,7 @@ static size_t rtllib_rx_get_hdrlen(struct rtllib_device *ieee,
struct rtllib_hdr_4addr *hdr = (struct rtllib_hdr_4addr *)skb->data;
u16 fc = le16_to_cpu(hdr->frame_ctl);
- size_t hdrlen = 0;
+ size_t hdrlen;
hdrlen = rtllib_get_hdrlen(fc);
if (HTCCheck(ieee, skb->data)) {
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index 19c3bff..25b5b5e 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -776,7 +776,7 @@ inline struct sk_buff *rtllib_authentication_req(struct rtllib_network *beacon,
struct rtllib_authentication *auth;
- int len = 0;
+ int len;
len = sizeof(struct rtllib_authentication) + challengelen +
ieee->tx_headroom + 4;
diff --git a/drivers/staging/rtl8192e/rtllib_softmac_wx.c b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
index 86f52ac..01a75bd 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
@@ -243,7 +243,7 @@ int rtllib_wx_get_rate(struct rtllib_device *ieee,
struct iw_request_info *info,
union iwreq_data *wrqu, char *extra)
- u32 tmp_rate = 0;
+ u32 tmp_rate;
tmp_rate = TxCountToDataRate(ieee,
ieee->softmac_stats.CurrentShowTxate); |
