USB: speedtch.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Duncan Sands
Reviewed-by: Felipe Balbi
drivers/usb/atm/speedtch.c | 18 ++++++++++++------
1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/atm/speedtch.c b/drivers/usb/atm/speedtch.c
index 0dc8c06..0270d13 100644
--- a/drivers/usb/atm/speedtch.c
+++ b/drivers/usb/atm/speedtch.c
@@ -255,7 +255,8 @@ static int speedtch_upload_firmware(struct speedtch_instance_data *instance,
usb_dbg(usbatm, "%s entered\n", __func__);
- if (!(buffer = (unsigned char *)__get_free_page(GFP_KERNEL))) {
+ buffer = (unsigned char *)__get_free_page(GFP_KERNEL);
+ if (!buffer) {
ret = -ENOMEM;
usb_dbg(usbatm, "%s: no memory for buffer!\n", __func__);
goto out;
@@ -638,7 +639,8 @@ static void speedtch_handle_int(struct urb *int_urb)
goto fail;
- if ((int_urb = instance->int_urb)) {
+ int_urb = instance->int_urb;
+ if (int_urb) {
ret = usb_submit_urb(int_urb, GFP_ATOMIC);
schedule_work(&instance->status_check_work);
if (ret < 0) {
@@ -650,7 +652,8 @@ static void speedtch_handle_int(struct urb *int_urb)
return;
fail:
+ if (int_urb)
mod_timer(&instance->resubmit_timer, jiffies + msecs_to_jiffies(RESUBMIT_DELAY));
@@ -759,11 +762,13 @@ static void speedtch_release_interfaces(struct usb_device *usb_dev,
struct usb_interface *cur_intf;
int i;
- for (i = 0; i < num_interfaces; i++)
- if ((cur_intf = usb_ifnum_to_if(usb_dev, i))) {
+ for (i = 0; i < num_interfaces; i++) {
+ cur_intf = usb_ifnum_to_if(usb_dev, i);
+ if (cur_intf) {
usb_set_intfdata(cur_intf, NULL);
usb_driver_release_interface(&speedtch_usb_driver, cur_intf);
static int speedtch_bind(struct usbatm_data *usbatm,
@@ -787,7 +792,8 @@ static int speedtch_bind(struct usbatm_data *usbatm,
return -ENODEV;
- if (!(data_intf = usb_ifnum_to_if(usb_dev, INTERFACE_DATA))) {
+ data_intf = usb_ifnum_to_if(usb_dev, INTERFACE_DATA);
+ if (!data_intf) {
usb_err(usbatm, "%s: data interface not found!\n", __func__);
return -ENODEV;
+ if (!buffer) {
ret = -ENOMEM;
goto out;
goto fail;
+ if (int_urb) {
if (ret < 0) {
return;
fail:
+ if (int_urb)
int i;
+ if (cur_intf) {
return -ENODEV;
+ if (!data_intf) {
return -ENODEV;
