staging: rtl8192u: Removed redundant bool comparisons in r8192U_dm.c
Author: Harisangam Sharvari <sharisan@visteon.com>
This patch was detected with the help of coccinelle tool.
The redundant comparisons of bool variables are removed in r8192U_dm.c.
Signed-off-by: Harisangam Sharvari
 drivers/staging/rtl8192u/r8192U_dm.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8192u/r8192U_dm.c b/drivers/staging/rtl8192u/r8192U_dm.c
index 416a1dd..7ca5d8f 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.c
+++ b/drivers/staging/rtl8192u/r8192U_dm.c
@@ -563,7 +563,7 @@ static void dm_TXPowerTrackingCallback_TSSI(struct net_device *dev)
 					break;
-			if (viviflag == true) {
+			if (viviflag) {
 				write_nic_byte(dev, 0x1ba, 0);
 				viviflag = false;
 				RT_TRACE(COMP_POWER_TRACKING, "we filtered the data\n");
@@ -766,7 +766,7 @@ void dm_txpower_trackingcallback(struct work_struct *work)
 	struct r8192_priv *priv = container_of(dwork, struct r8192_priv, txpower_tracking_wq);
 	struct net_device *dev = priv->ieee80211->dev;
-	if (priv->bDcut == true)
+	if (priv->bDcut)
 		dm_TXPowerTrackingCallback_TSSI(dev);
 	else
 		dm_TXPowerTrackingCallback_ThermalMeter(dev);
@@ -1301,7 +1301,7 @@ void dm_initialize_txpower_tracking(struct net_device *dev)
 	struct r8192_priv *priv = ieee80211_priv(dev);
+	if (priv->bDcut)
 		dm_InitializeTXPowerTracking_TSSI(dev);
 	else
 		dm_InitializeTXPowerTracking_ThermalMeter(dev);
@@ -1357,7 +1357,7 @@ static void dm_check_txpower_tracking(struct net_device *dev)
 #ifdef RTL8190P
 	dm_CheckTXPowerTracking_TSSI(dev);
 #else
+	if (priv->bDcut)
 	else
 		dm_CheckTXPowerTracking_ThermalMeter(dev);
@@ -1467,7 +1467,7 @@ void dm_cck_txpower_adjust(struct net_device *dev, bool binch14)
 {	/*  dm_CCKTxPowerAdjust */
+	if (priv->bDcut)
 		dm_CCKTxPowerAdjust_TSSI(dev, binch14);
 	else
 		dm_CCKTxPowerAdjust_ThermalMeter(dev, binch14);
@@ -3062,7 +3062,7 @@ static void dm_dynamic_txpower(struct net_device *dev)
 			priv->bDynamicTxLowPower = false;
 		} else {
 			/* high power state check */
-			if (priv->undecorated_smoothed_pwdb < txlowpower_threshold && priv->bDynamicTxHighPower == true)
+			if (priv->undecorated_smoothed_pwdb < txlowpower_threshold && priv->bDynamicTxHighPower)
 				priv->bDynamicTxHighPower = false;
 			/* low power state check */
BtrLinux
