mfd: wm8350-core: Pass the IRQF_ONESHOT flag
Author: Fabio Estevam <fabio.estevam@freescale.com>
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
So pass the IRQF_ONESHOT flag in this case.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/irqf_oneshot.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Lee Jones
 drivers/mfd/wm8350-core.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mfd/wm8350-core.c b/drivers/mfd/wm8350-core.c
index f5124a8..8a07c56 100644
--- a/drivers/mfd/wm8350-core.c
+++ b/drivers/mfd/wm8350-core.c
@@ -404,7 +404,8 @@ int wm8350_device_init(struct wm8350 *wm8350, int irq,
 	if (wm8350->irq_base) {
 		ret = request_threaded_irq(wm8350->irq_base +
 					   WM8350_IRQ_AUXADC_DATARDY,
-					   NULL, wm8350_auxadc_irq, 0,
+					   NULL, wm8350_auxadc_irq,
+					   IRQF_ONESHOT,
 					   "auxadc", wm8350);
 		if (ret < 0)
 			dev_warn(wm8350->dev,
BtrLinux
